Lubricating proof meter cable?
   / Lubricating proof meter cable?
On my 1951, I just stuck a new one in dry, as it came out of the plastic bag, on the day the old one failed (at 1500 hours). They had one in stock at the farm store around the corner. I don't remember it being very expensive. Currently, I have around 500 additional hours. You should be able to get that with no lube anyhow. How many hours did yours fail at? What did the new one cost? That sounds like a bit of a messy job that I would skip unless the cable was expensive and/or I had lots of free time. It would be interesting to know the average difference in lifespan of a lubed or un-lubed cable. I know it is hard to believe, but sometimes too much lube can do more harm than good.
Well, the cable and meter were not working when I bought the tractor, so I'm not sure how long ago it gave up. The meter read 2812.6 hours when it stopped working, but that was apparently looooong before I purchased the tractor. You can see how dark the numbers are, but if you look closely, you can see that the number dial is white where I wiped a little of the smut off of the dial. It was only dirty on those numbers exposed, the back side was still white! The new cable was something like $20, I don't remember exactly. It's the all metal sleeve and seems pretty sturdy. It was actually fairly easy to take apart, only one little c clip on the governor side. It slid right out I lubed it up lightly with lithium grease except for the last few inches on the meter side, then slid it right back in and reinstalled the c clip. Total of about 5 minutes start to finish. Seems like minimal effort to me to do the extra step w/o cutting corners for peace of mind type of thing.
I have not gotten around to trying the jbweld yet, but hopefully this weekend I will have time to try it out and get the meter back together and installed. I'll put up some pictures if everything goes well (or if it doesn't as well) :) image.jpg image.jpgimage.jpg
   / Lubricating proof meter cable? #12
Good luck with it. You have there my favorite tractor ever. If it behaves anything like mine, I am sure you will have many years of great service. I still cant believe how much easier it is to change 3-pt implements on those "originals" than any make/model made since. Also, as you have seen, getting parts is always a "walk in the park". With my tractor, I am sure of the hours because it was purchased new by our neighbor across the street. All he did with it was work a small garden each season. He was a stickler for maintenance and his widow gave me all them records, plus the original sales info when I bought it.
Well, I have good and bad news. The good news is that the jbweld worked wonderfully to repair the stripped out socket on th back of the meter! The bad news though is that either A: I screwed up something in the meter when I took it apart, or B:it was already no good to start. It kind of works, but I think either the spring is worn out or the magnet has lost some of its strength. They just don't seem to play well consistently together.
Before I put it back together I had the cable connected to the meter and a cordless drill on the governor end. The drill has a max rpm of around 1700 so I thought that would be a good speed to test things out. Sometimes the needle would bounce around about 900, other times it would be closer to 2400 with no rhyme or reason for one or the other. Maybe it just needs adjusting or tuning or something, but I don't see how that would be done. The gears all turn and the hour meter works, the tach is a whole different animal.
I think this one has surpassed the $50 value mark for me to try to repair, so I believe I'll be ordering a new one.
If anyone out there rebuilds these things and wants to give this one a shot, just let me know.
   / Lubricating proof meter cable? #14
the lil shaft the needle runs on may need some lube.. try that. if not. yeah.. it's likely a gonner...
I actually did put a little grease on the gears and the needle hoping that could help, but no such luck. I already put the glass back in and the bezel back on and figured it was more or less a decorative paper weight now. Oh well, it was worth a shot!
   / Lubricating proof meter cable? #16
and the new ones aren't mucch better. :)
just a few words of encouragement. ;)
Well if I can put as many hours on it that the first one did I should be set for the next couple decades at least. :D
   / Lubricating proof meter cable? #18
if you can get them in in 6m you'll probably be ok. ;)
Is that 6 minutes or months? Because 6 minutes doesn't sound unreasonable for install. It's a pretty simple set up.....however I did go with a guage kit with the new ammeter and oil guage. And the proofmeter has a light! So there's another couple minutes running new wires....I'm thinking two beer job tops :thumbsup:
   / Lubricating proof meter cable? #20
if you can get all those hours in in 6 months you might be ok. because that's about the lifespan of some of the new proofmeters! :)
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
black Max power washer (A53421)
black Max power...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A53473)
Gooseneck...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
