X485 Transmission Oil Cooler Location?
   / X485 Transmission Oil Cooler Location? #1
italyguy01
Member
Pa
X485
Is the Transmission oil cooler behind the radiator? Manual says to clean the transmission oil cooler fins, but doesn't specify location.
Thanks!
   / X485 Transmission Oil Cooler Location? #2
Thanks!
My 445's (which were the forefather of your machine) had theirs inside the radiator.
Maybe the manual meant to clean the rad fins to make sure of proper cooling of both the engine and trans. It wouldn't be the first mistake in a JD manual, believe me.
Looking at the parts break down on JD parts, it looks like you should be able to follow the two hydraulic lines from the trans up to the cooler.
Thank you!!
2016 International ProStar T/A Sleeper Cab Truck Tractor (A51692)
2016 International...
PNEUMATIC GREASE UNIT (A53843)
PNEUMATIC GREASE...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
Unused 2025 Bale Spear Skid Steer Attachment (A51691)
Unused 2025 Bale...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
