Fuel filters keep clogging
   / Fuel filters keep clogging #1
bmschreier
Elverta, CA
2007 New Holland TC30
Hi Everyone,
First post since getting my (new to me) TC30. 2007 with 110 hours. Since January I have been having a problem where the engine starts stuttering and loosing power. It took me awhile the first time, but I solved the problem by replacing the fuel filter. Well, now I have to replace the fuel filter every 10 hours or the same thing starts happening. I've put a couple tanks of fuel through it, from different gas stations, with no difference. I even tried adding Power Service Clear Diesel this last time, but the filter clogged again. I use sta-bil in all my diesel.
At no point have I seen anything more than a few flecks in the bowl, and the filter "looks" brand new (would a filter ever "look" clogged???), but time and again changing the fuel filter fixes the problem. I've probably gone through 4 filters now.
So, I assume this means that my tank is full of some kind of sludge, but with such a low hour tractor, would that be possible? Wouldn't this gunk show up on the filter or in the bowl? Any way to check the tank without removing it? Is there another explanation?
Thanks for any advice!!
Brian
   / Fuel filters keep clogging #2
I would siphon the fuel out and put it in a 5 gal bucket so I could see what was in it, If it looks clear I would keep it and use. I might also see if I could pull the fuel line off near the tank and drain the tank into a bucket, that would get more trash ect. than siphoning. Wish you well, Keep us posted.
   / Fuel filters keep clogging #4
Hi Everyone,
Brian
I know this is going to sound strange, (especially as you have tried different dealers) but I went to the station closest to my home when I first got my tractor. They had an above ground tank. After running the tractor for 15 to 30 minutes it would start sputtering and dying.
I changed to a station a few miles further away, with an underground tank, and I have not had the problem again. I think that (in my case) the above ground tank is much more sensitive to temperature change and therefore gumming then underground tanks.
This may not be your problem, but I had to change my filters 3 times the first summer and now only once a year (100 hours)
   / Fuel filters keep clogging #5
Is it an inline filter that keeps getting plugged? I'm only asking because I work as a mechanic for a rental company and our inventory gets transferred to other branches frequently, and often when the machinery gets back to us we end up having fuel filter plugging issues because inline filters had been installed elsewhere that were never intended for use with diesel fuel. One example that we just cannot seem to get everyone on the same page for, is the common see-through plastic inline filter with a paper element such as CarQuest p/n 86002, (Wix p/n 33002). Lots of people LOVE to put them on everything, because they're able to "see" if the element is getting plugged.
They'll last for a few hours passing diesel fuel and then start plugging up....because, (as it says right in the manufacturer's literature), they're not meant to be used with diesel fuel in the first place.
   / Fuel filters keep clogging #6
You have a contaminated fuel system. Diesel bugs. You need to drain your tank completely, wash it out, fresh fuel, fresh filter, biocide, diesel treatment, then watch it closely.
Chris
   / Fuel filters keep clogging #7
Make sure filter is plumbed right.
   / Fuel filters keep clogging #8
Like DP says....Likely you have water and bio sludge in the tank. A real pain, but remove the tank and clean it.
I fought the very same issue. Until I dropped the tank, it kept coming back.
Thanks for all the replies!
I have tried running the tractor with the fuel cap off once it starts bogging down...no effect. There's no inline fuel filter, just the stock one. The first filter that clogged was a NH, but the rest have been NAPA gold filters (presumably fine for diesel?).
I have drained the tank through the fuel outlet and didn't notice any sludge, but it looks like the next step is to remove the whole thing and clean it more thoroughly. Hopefully that's not as much of a pain as it sounds. The filler neck is bends around a bit...do most people try to get a brush in there and physically clean it, or just put some fuel in and slosh it around?
Thanks again!
   / Fuel filters keep clogging #10
I'm going through the same thing right now with my GMC 3500 diesel and after chasing the problem for quite some time we found the problem to be algae inside the tank. It finally plugged up the filter in the tank to where it would not run. Prior to that it would idle all day, but when you went down the road it would starve for fuel. Fuel tank was the last thing we looked at, but that was the problem. Good luck.
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
CAT 336E (A58214)
CAT 336E (A58214)
23105 (A56859)
23105 (A56859)
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
