Buying Advice Chinese backhoe manufacturer
   / Chinese backhoe manufacturer #11
It had a single plate on each side of the swivel on both the upper and lower pivots causing both pins to wear unevenly and be loose. I added another plate on both the top and bottom pivots and made 2 longer pins to span the larger gaps this created.
A BH with a self contained hydraulic system driven by it's own PTO pump is what I would reccomend. You also beat me to the last suggestion. A subframe is a good idea if you plan on doing anything serious with it like this:)
Yup! That was the pic that confirmed my sub-frame need. ;-) I, luckily, do not have any trees like that on my lot, nor boulders, or hard clay. I have mostly light sandy soil.
   / Chinese backhoe manufacturer #13
Once you get the bugs, defects, and leaks out of these, you end up with a really powerful unit except for the swing capability. There are various photos of my BH with sub-frame on this site. I ordered a 6 foot hoe and ended up with a seven foot!
If you choose to self import I recommend you buy factory direct and not from an offshore based trading company who has no presence in the USA. Don't be fooled by photos or text on their websites. When I imported mine several years ago I ordered two repair kits for every cylinder, two spares for every hose, one spare pump, extra bucket teeth, and at least a dozen of the lollipop shaped wire locks on the cylinder pins. After it arrived, fully accompanied by missing parts, defects, etc., I spent maybe another $500-800 on repair welding and fabrication to fix the non-fitting frame, cylinder repair by re-honing, etc. I even traded wrong parts to Tommy for the right ones. Thanks to Tommy @ Affordable!
I bought directly from Jinma although I believe the BHs were made by others. They were superb and apologetic about solving problems and replacing parts. We are an importer and I believe they treated us well because of that. I think we were not regarded as a one time only retail sale.
Import duty on farm equipment at that time, two years ago, was zero. The price of the BH alone, CIF Boston was just under $2K. Then came the broker costs, inland freight, etc. I think the total investment from start to finish, including weld repair totaled around $3500 not counting the hours I spent chasing leaks, claiming defects, lost time, time spent repairing and not using, etc.
Your options are:
1) Self Import and take your chances
2) Buy same item from USA based importer with reputation and willingness to give you names and phone numbers of recent satisfied customers of same BH
3) Buy Korean BH or equivalent from reputable USA source
Thanks, Steve for your advice and history on both my questions.
   / Chinese backhoe manufacturer #15
i picked up a vtek backhoe for 2k. i used is to do a lot. transplanting a dozen 6 feet tall citrus was the big job it did. only had one issue with a cylinder seal. it has its own sump and pump that goes to the pto.
as far as subframe mounting, it can lift the back end of the tractor up, it is only 3pt mounted. i don't see a need for the subframe to be honest, i have it hooked to a harbor freight quick attach. didn't modify anything.
one thing though is that it isn't as strong as id like it to be, mainly digging into the top layer, but after that it does what it should for a 12" bucket. great for footers, transplanting, digging holes to bury dead animals.
   / Chinese backhoe manufacturer #16
Does anyone have experience with Weifang Yijia Imp. & Exp. Co., Ltd. and their attachments? I am currently negotiating for a 3 pt backhoe, and wonder if anyone knows about quality and problems with payment?
Another question: is there US duty and tariffs due on these attachments when entering the US?
Any help is appreciated.
I know this company, this is a typical trading company on alibaba, because I m also manufacturer in China:laughing:
I don't know which factory they buy backhoe from, so my suggestion is that you should ask them provide the backhoe photo which will sell to you, but not those marketing photo. I also have many photo for LW backhoe, too many factory in China produce them.
Thanks, Jack. I will follow your advice if/when in the future I do business with a business in China.
   / Chinese backhoe manufacturer #18
I mean that suggest you ask for their photos as more as they can, to buy something oversea, it will always surprise you when you see the real product, but the photo is the only way for you to feel them.
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
Miles read : 112,969 (A50323)
Miles read ...
