5525 2nd and 3rd valve hard to get lines into the valves
   / 5525 2nd and 3rd valve hard to get lines into the valves #1
cowboy11
homewood
5420/5525 john deer 6610 ford 3910 ford
5525 john deere cab model when cutting hay with krone conditioner/cutter very difficult to hook lines into vlaves sometimes take as much as 30 minutes
struggling to hook them up . once they connect all works well. it also is very difficult to unhook these lines works with no problems on 5420 deere anyone
experience this . :confused2:http://www.tractorbynet.com/forums/images/smilies/new/confused2.gif
   / 5525 2nd and 3rd valve hard to get lines into the valves #2
If this is the only implement you have issues with, change out the couplers on the implement.
Problems going in May be pressure buildup in the lines. Push the coupler face against a flat surface until it depresses the ball. If it is pressure build up, oil will shoot out. It should connect easy then. To disconnect, try shutting 5420 off and moving SCV lever to remove line pressure and then push in and yank back.
thanks I will give it a try it has been a b---- tries your patience :cool2:
   / 5525 2nd and 3rd valve hard to get lines into the valves #4
I wonder if coupler attachment problem was why JD changed the type of breakaways on a 5525.
2020 Chevrolet Tahoe SUV (A52377)
2020 Chevrolet...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
