5 Gallon Diesel Fuel Can
   / 5 Gallon Diesel Fuel Can #11
Thanks for all the replies. I guess I'll just put enough fuel in the can to reach the safe fuel mark and whatever amount it turns out to be, then that is what it is!
That is the way I play it.....but I usually under fill them by a good margin. I have trouble lifting them anymore.
   / 5 Gallon Diesel Fuel Can #12
Not sure how much below the mark "just below the mark" is as you define it.
5.071 gal is 5 gal and 9.08 oz. That is basically a cup. Did you get down level with the line, or look at an angle from above as you were pumping?
.071 gal would be 16.4 cu inches of fuel.
My 5 gal cans are 8.5 wide by 13 long thus with 231 cu inches per gallon the height difference of the depth of 16.4 cu inches (.071 gal) is only 0.148 inches (between 9/64 inch and 5/32 inch)
That is barely over 1/8 inch.
With the fuel sloshing you would have to wait for nearly a minute for all motion to subside before you could adequately see that difference. On top of that as soon as you pickup or set down the can (assuming it is plastic and to see through it it must have been) the deformation of the weight on the container sidewalls will change the height of the fuel due to sidewall deformation of the container.
Not defying physics just calculating math.:)
Oh by the way my cans full marks that are embossed on the plastic are slightly wider than 1/8 inch so that is the same introduced error that your 0.071 gal had in depth.
Testing is down by the state at cycles and is marked on each pump.
To test it your self get a measuring cup and have at it.:D
Now, Furu, that was a heck of a lot of thinking and calculating.:D
   / 5 Gallon Diesel Fuel Can #13
'Taint funny McGee...I have the same affliction. Used to lift a 5 gallon can of wet cement; now I'm tempted to haul my 5 gallon can of gas with my trailer and tractor...and I will, if tempted...I know, I've seen me do it! (with apologies to Ron White).
   / 5 Gallon Diesel Fuel Can #14
I can still put them up on the hood of the Kioti, but the big 60 is approaching fast, and perhaps some day I may not be able to do so. I am wondering what I am going to do then, and I am betting it it going to involve some money to solve that problem:D
   / 5 Gallon Diesel Fuel Can #15
Silly begets silly.
Took longer to type than it did to do the calcs so not much calculating, and as far as thinking most of that was trying hard to not let the :rolleyes: drip through.:D
James: You are the only one to appreciate it. Thanks.
   / 5 Gallon Diesel Fuel Can #16
Silly begets silly.
To the original poster, did you know if you shut the pump off and then elevate the hose while holding in the lever you cant get about .071 gallons "extra" out of the hose?:D
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
2022 CATERPILLAR 302.7 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2015 CATERPILLAR CT660 TANDEM AXLE DUMP TRUCK (A54313)
2015 CATERPILLAR...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2011 International WorkStar 7300 Hazardous Material Tanker Truck (A52377)
2011 International...
