The trick is to go forward ... And the truth is virtually anything the tractor can bend down so the bushog blades hit is history. Think of an ax wielded by several tens of HP. By far the greatest capability is forward so that the bh frame doesnt bear the brunt of bending the tree.
,,, When I was in my late 30s I did light woods clearing type mowing with the JD 2010 and 5' JD127 Gyramor. It had 1/2" thick 10" knives at the end of a 3'+ solid carrier arm - no stump jumper. I remember when my dad bought it that the dealer said it had a 125HP gearbox, but, judging from its frame, medium duty. The tractor was a tricycle type having rear axle case setting about 28 inches high. That would allow me to bend a pretty good sized oak tree [4"] and cutting was trivial as opposed to if tried backing up. I noted a set of 2" holes thru the bellhousing well forward of the axle and about 4 feet high. I put a 1-3/4" steel rod thru there and bushed it with plastic so the housing wouldnt be cracked if the rod bent. TREMENDOUS difference. I could push over awesome trees with this bigwheel 2wd tractor! ... Visualize 20' high trees falling forward right next to you. Literally anything 6" or less would bend over and get chopped by the 45HP ax. Many slightly larger would too. Some would stop the tractor as the ballasted AG on that side unweighted. I learned to stop there or the rod would bend. It was truly an adventure.
,,,I now have a pretty strong Rears flail. Much heavier. But truly pitiful at dealing with the stuff that 600 pound bushog did ... and still will.
larry
