JD MX-6 repair
   / JD MX-6 repair #1
farmglide
Brookfield MA
JD 4320
I just finished repairing my JD MX-6 rotary brush cutter after the output shaft snapped as many others have done.
I found a 150HP gear box at D&N equipment in Ohio that I was able to use with a little modification to the deck ( adding two mounting holes and elongating the existing four) and the stump jumper ( drilling the center hole out to 1 1/32 and counterboring the bottom 1 1/2 dia X 7/16 deep. The counterboring is because the new gear box has a threaded shaft and the stumpjumper is held on with a 1" jam nut with red lock tight. If the threaded shaft was a little longer you could use the castle nut provided.
D&N told me they also have a 75HP unit that requires less work to install but I wanted to go big so I don't have to worry about doing this again. The new gear box is massive!! but dropped right inplace.
All in the repair cost me $1000 or less than half what JD wanted and now i have a 150HP gear box and the satisfaction of fixing it myself and not giving JD another dime to fix something that is clearly their poor part quality.
I used the cutter for a few min after assembly and it worked fine!
FG
   / JD MX-6 repair #2
Glad you got it done.
Considering that your tractor is less than 50hp, that 150hp gearbox should last a while. :D
Just curious. I read the other posts on this repair, but I didn't see anything about a slip clutch. Does your unit have one, did you adjust it prior to the shaft failure, and is it working properly?
   / JD MX-6 repair
BIGFOOT62
Yes there is a slip clutch and I followed the adjustment procedure to ensure it was not frozen up with rust.
when I posted before I forgot i had to purchase an adaptor to mate the new gear box to my drive shaft. the gear box input splined shaft is a larger diameter so I needed to go up in size. That was another $150 so total cost of the repair was more like $1150.
RG
   / JD MX-6 repair #4
BIGFOOT62
RG
Sometimes the slip clutch just won't do it, but your chances are better with one than without one.
Sounds like your case it was just a weak part.
At any rate, glad you got it back up and going. Doing it yourself and saving a few bucks always feels good. :thumbsup:
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
TROY BILT PRESSURE WASHER (A51248)
TROY BILT PRESSURE...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
