trying to remove the starter on my 1948 Ford 8N tractor.
   / trying to remove the starter on my 1948 Ford 8N tractor. #1
ladybear
Narrowsburg, ny
1948 Ford 8N
have been trying to get the starter out of my '48 ford 8N tractor but get hung up on the flywheel. Any suggestions :confused2:
   / trying to remove the starter on my 1948 Ford 8N tractor. #2
remove the bbl band on the starter especially if the clip faces the block, remove the drain petcock.
angle the rear of the starter in to block and down, so that the drive gear on the shaft is coming out of the hole at about the 2 oclock location. in that location the drive gear is about as far away from the ring gear as it is gonna be.. and then you have to jocky it between the bellhousing and ring gear in a side to side seesaw motion.
many tractors have that 2 oclock area hollowed out with a file so that it looks like a hole overlaying another hole. many people file the hole out if there is not already like that.
in the end. hold yer touge just right usually helps too.
ps.. when you get it slid back a lil. pop a couple nuts on the 2 long bolts to keep from pulling the starter field casing off the armature.. or you'll be posting back how to capture the brushes and get the armature back into the field housing. :)
Thanks for the info. So (not) looking forward to trying it. At the risk for sounding totally dumb, I know the firing order on the motor, however, I do not know the location of the #1 cylindar. Is it the one closest to the radiator or to the back of the tractor?
   / trying to remove the starter on my 1948 Ford 8N tractor. #4
Front. Closest to radiator.
   / trying to remove the starter on my 1948 Ford 8N tractor. #5
removing the starter will be easy.. may just be time consuming getting all the stars to line up to get it over the ring gear.
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A56138)
1999 INTERNATIONAL...
ACS 104" HYD PIN ON PIPE GRAPPLE (A52707)
ACS 104" HYD PIN...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
