Hydraulic Valve body rebuild
   / Hydraulic Valve body rebuild #1
Rat Rod Mac
I have an old John Deere 350 dozer that needs the valve body rebuilt. First off can the spools be removed without taking the valve body out of the box? Second, has anyone on here done this before, and if the spools are ok do I just replace the O-rings. Any other information you can give me would be greatly appreciated.
Also, on the cylinders, is there a place to buy rebuild kits that are good but not pay the high John Deere factory prices? Thanks in advance. RRM
   / Hydraulic Valve body rebuild #2
Yes, you can remove the spools by removing the cans on the bottom and remove the nut in the end of the spool. The spool should slide out.
I can't say that a rebuild kit won't work, however, spools are not designed to be replaced as the fit in the bore is precise.
The o-rings on spools are design to keep crud out. not hold pressure.
If a spool is leaking, it is leaking at a certain rate, and most manufacturer have a go/no test in drops per minutes leakage rate whether they replace a spool.
If the valve/dozer is out of warranty, it will be up to you as to what you can accept.
In most cases, a new valve is called for.
   / Hydraulic Valve body rebuild #3
If you carefully measure the sizes of the cylinder seals, and pay close attention to their
cross-sectional shape, you can usually find replacements in the Hercules Hydraulic catalog.
I have used them before and they are indeed less money than JD.
Hydraulic cylinder repair seals and kits-Hercules Sealing Products - Hydraulic Seals and replacement cylinders for construction and many other heavy equipment industries.
Thanks for the information. RRM
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
19010 (A48082)
19010 (A48082)
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2016 HITACHI ZAXIS 210LC-6N EXCAVATOR (A51242)
2016 HITACHI ZAXIS...
