How do I get this cylinder housing off? See pics
   / How do I get this cylinder housing off? See pics #1
jdl25
Wendell, NC
Kubota L185, L2650
Kubota L185
having trouble getting the 3 point lift cylinder housing removed. I have taken out 8 bolts and 2 nuts, nothing. I tried to push against a stud and lift the housing with a pry bar, nothing. I tried to hit it around the perimeter with a dead blow, nothing. Then I bolted up an engine hoist to it and I think it will lift the tractor. Are they just that tight? I am about to try to wedge something between the housing and the transmission case.
Any advise or experience to share? Please see pics.
Thanks
   / How do I get this cylinder housing off? See pics #2
Looks like you have all the bolts out, so yes, apparently yours is going to need A LOT of persuasion. I'd try a combination of using the lift and tapping around it with a sharp chisel to try so get in between the trans case housing and the rockshaft housing. Kubotabooks.com has a parts book for your machine, it shows the rockshaft diagram and all the nuts/bolts ( looks like 10) that have to be removed. The fist time I had to remove my trans cover, it was a bear! I think I too could have lifted the tractor by the case and it wouldn't have separated.
I was hoping that I had missed a bolt, but I think it is time to wedge it.
   / How do I get this cylinder housing off? See pics #4
still need to take off 3 point arm linkage. may be stuck on dowel pins
Yes, but they will come right off they are not in a bind. I had just put them back on because I was tired of them being on the floor.
Thanks for the idea though
   / How do I get this cylinder housing off? See pics #6
put some pressure on it with your chain hoist and hit where your top link goes with a hammer
I left it with a little pressure on it and will try hitting it tomorrow while pressure is applied, thanks for the suggestion
   / How do I get this cylinder housing off? See pics #8
I think his top link pin ears bolt to the rear trans case and the rockshaft housing isn't bolted to it, just sits behind the top of it.
   / How do I get this cylinder housing off? See pics #9
In my younger day we overhauled various compressors and other industrial machinery so am well aware of your dilemma. We used some thin steel wedges to break the seal of glued down gaskets. Found some at McMaster Carr see this link. McMaster-Carr
It is easy to break casting if you apply too much pressure in one place. We used four or more on large surfaces. The pipe flange ones are longer and thinner on the end. We used both. Did big pipe flanges also.
Ron
   / How do I get this cylinder housing off? See pics #10
I think thats a good idea, maybe lift it higher also.
I noticed at the rear, you could possibly get a "paint scraper" of some sort in-between the gaskets.
Maybe some sort of "degrease spray" sprayed in the cracks and at the back section,
where it can seep between the gaskets.
TRAILER TIRES & WHEELS (A51248)
TRAILER TIRES &...
RIGID TOOLBOX (A52472)
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
Wacker Neuson DT08 (A50123)
Wacker Neuson DT08...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
