Making quick attach pallet forks from scrap around the shop
   / Making quick attach pallet forks from scrap around the shop #1
RogueFab
Member
Sandy, Oregon
New Holland T2420
I know you all will hate this... They are going to be fixed width! I want them rigid, and the pallets I handle have a small range of widths. These are going to be simple, and rated for a ton (total) with a safety factor of 2.0.
Starting with the only purchased part/material: Quick Attach plate. 5/16 and 3/8 A50 steel. Less than $100 delivered, and saves a day of fab work since we don't have tools to mess with plate.
Next we bent up some 1 inch .095 wall square stock for a material safety rack. It won't stop a one ton hay bale, but I don't do hay work ;)
   / Making quick attach pallet forks from scrap around the shop #2
Looks like you have a good start on your project. A minor suggestion if you will (from a non-expert novice) so take it for what it's worth. I would build your frame with the outer sections running down the outside of your quick attach plate. It would provide a lot more structural rigidity. I modified your photo and added some red lines to indicate where I am referring. Keep us posted on how this goes as I am considering either the purchase or the fabrication of a similar setup.
Mike
I have had them done for a while now. I have moved plenty of stuff (compressor, logs, pallets of material, etc). Love them.
2009 CAT 140M MOTOR GRADER (A55745)
2009 CAT 140M...
2017 Mitsubishi Mirage G4 Sedan (A55758)
2017 Mitsubishi...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2025 Two Tall Dump Wagon (A53314)
2025 Two Tall Dump...
Rotadairon RD100 III Rotary Soil Tiller Tractor Attachment (A55851)
Rotadairon RD100...
New/Unused Quick Attach Rock Breaker (A54865)
New/Unused Quick...
