City Estate Living...London's buried excavators
   / City Estate Living...London's buried excavators #1
bcp
Super Star Member
SW WA
Kubota BX2360
New Statesman | The bizarre secret of London
From the link above:
I've made a discovery about what is buried under the swimming pools and basement conversions of wealthy west London. This booty is worth about 」5m. More revealing, however, is another fact: this 」5m was tossed away like small change tipped into a busker's hat. It is not **** art, or plutonium that has been used to kill the enemies of Russian oligarchs. It is a fleet of diggers.
How many of these once perfectly functioning and possibly still serviceable diggers are petrified underneath central London, like those Romans preserved cowering in the corners of houses in Pompeii? Estimates vary. One property developer I asked reckoned at least 1,000; another put the figure at more like 500.
   / City Estate Living...London's buried excavators #2
Some people have too much Money :shocked: , they could rather given some of the money they waste to me :D
   / City Estate Living...London's buried excavators #3
I'm pretty skeptical. Sounds like a bit of a hoax to me, and not a single supporting pic. It would have to be small digger in the first place (VERY small for 5000 pounds) so I'd imagine it would be relatively easy to dismantle and lift it out with a small boom crane.
Also, how are they getting out all the dirt that this digger is supposedly removing?Carrying it out in their pockets or trouser cuffs perhaps.
   / City Estate Living...London's buried excavators #4
I dunno, sounds like they are talking about the ones small enough to drive through a door. Easy enough to just park it in a corner and build around it.
   / City Estate Living...London's buried excavators #5
I used to work with a woman whose husband had a business putting basements under houses that had no basements, rebuilding foundations, etc... he would knock a small man-sized hole in the side of the foundation just under the sill plate and crawl in on his belly. He'd scoop dirt into buckets and hand them out to his sons, who would dump them on a conveyor attached to the back of an old 1940's dump truck. Repeat. Once he got enough room to work in his hole, he'd have the boys lower in another conveyor and he'd dump the bucket into that, the dirt went out the man-hole into a wheelbarrow, the boy up top would dump it into the conveyor on the dump truck. Repeat. Buckets, wheelbarrows, conveyors and strong backs. That's how you get dirt out from under houses. YIKES! Just think of what he could have done if he had enough room to lower in a mini excavator or a Power Trac like mine without the ROPS.
   / City Estate Living...London's buried excavators #6
Try to do that here and the epa would be all over you.
   / City Estate Living...London's buried excavators #7
I wish I could find a decent excavator for that kind of money. (5000 British pounds = 8400 US dollars) I'd take much better care of it, too. ;)
I have to call BS on this one... there is no supporting evidence. Besides, if real estate is that valuable who in their right mind is going to take up space just to bury a machine?
This on the other hand Canadian Man Excavates His Basement Using R/C Trucks Over 7 Years! | Singularity Hub
I found rather interesting.
   / City Estate Living...London's buried excavators #9
They were talking 1980's-90's and prior when this was going on that was 2x the money now. Most of these left behind excavators would be stripped down most likely to fit into/under the existing structures as well. It is pretty common practice in the underground world to leave equipment in the ground. Loot at mines, everything that goes down stays there even if it was still running when the mine went bust. Places like salt mines and the big tunnel boring equipment usually is wore out much faster so leaving them in place is no big deal, scrap value is about all that is lost. I worked for a company that made underground boring machines, smaller up to 10' across and yep customers often said one time use build cost of machine into cost of job. If it is pulled out when done it is paid for already and if not it was paid for...
Mark
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR SD-22-72W NO TILL SEED DRILL (A54757)
UNUSED LANDHONOR...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A54607)
2007 POWERSCREEN...
