Kubota M7060, M8560, M9960 price in Canada
   / Kubota M7060, M8560, M9960 price in Canada
Since I can't get tractor which I was about to buy (one year old kubota M9960 w. FEL) because owner in the last moment decide to keep it I would appreciate your opinion with some possible options and they real value for the new one which most likely I'm going to get.
I went to another dealership looking for used one and they offered me more attractive prices for new machines than my previous quote. Either M8560 or M9960 (Price difference is ~ $6000).
Thread is here:
http://www.tractorbynet.com/forums/...314617-some-tractors-options.html#post3800607
BTW my last quote is ~ 10% off Kubota's MSRP which is less than some of you guys can get in US :) and there is no "Build my tractor" at Kubota Canada website so it's hard to know what is an actual MSRP :)
   / Kubota M7060, M8560, M9960 price in Canada #23
Are they equipped the same? If so I would go with the M8560 as the tractors are the same even the same engine, we've never run out of power with our M8540. I would get bigger tires, ours has the same size tires as the M9540.
   / Kubota M7060, M8560, M9960 price in Canada #24
I agree with Larry if the tire option is available to you. Unless you are going to use this tractor for heavy tillage all the time, you'll not miss the 10HP. If you go with the 8560 I'd definitely try to get the larger tires.
If you want I can go on Kubota's site and "build" both models and give you a US price??
Thanks for help. I can go there and do it by myself but it will not affect my local price.
   / Kubota M7060, M8560, M9960 price in Canada #26
Okay. I thought you meant you could only get a Canadian price and was wanting a comparison. No worries.
I just like to finalize it and move forward :)
   / Kubota M7060, M8560, M9960 price in Canada #29
Radial larger size tires. 12 speed. If using a FEL, 3rd function hydraulics. If you are going to use forks on the FEL moving bales a lot, self leveling FEL. 3 rear remotes. 2 speed PTO if you have PTO implements of both speeds. Cast iron rear wheel centers, because these tractors are light in the rear and you'll want to add fluid and/or cast iron wheel weights. I run cast centers, fluid and 300lbs of wheel weights.
Beyond those, there's nothing on the option list that I miss.
Thanks for your feedback!
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
Mobile toilet with shower (A53424)
Mobile toilet with...
2007 Ford Five Hundred (A55758)
2007 Ford Five...
3 PT QUICK HITCH (A54756)
3 PT QUICK HITCH...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
Cat TH407C Telehandler (A53472)
Cat TH407C...
