CobyRupert
Super Member
There is no correct way to rewire this circuit for a hot and a switch wire. NEC 250.119 says the green will be ground not anything else.
A breaker trips because of overload not because the fault current goes back to its source.
And those ugly bubble covers are made for the use of a cord that is never unplugged and are in wet areas (outdoor outlet covers are for the occasional use of that outlet).
All true. But there is no "overload" for the breaker to trip on if the fault current has a high resistance path (earth and not a low resistence ground wire) to get back to the source (transformer) and limits the fault current to less than the breaker's rating. Instead, every metal thing connected to the local "ground" (e.g. boxes, switches, fixtures, etc..) gets it's voltage raised waiting for someone to touch it. :lightningbolt:
