Welding 3/16" & 1/4" with 120v wire-feed
   / Welding 3/16" & 1/4" with 120v wire-feed #31
When the new 140E migs come in, I'll do a comparison video...should help solve some discussions, along with a bend test (hopefully) on 3/8" steel, just like it's done for test...root and face. Maybe do one against a 110V transformer mig and and a 240V MIG, like an ESAB or Miller...novice versus experienced?
When plugged into 120v, my MultiMatic 200 will not allow me to choose settings beyond 1/4". If I plug into 240v then I can choose all the settings, including the 5/16 and 3/8" settings.
I think it's time! (But its gonna make the boys on weldnet mad).
   / Welding 3/16" & 1/4" with 120v wire-feed #34
You can work a small machine past its capabilities no doubt, ive done it in the past, but it comes with experience. Smaller wire, pre heating, beveling, open roots etc, the reason we argue the fact constantly is people get a false positive of the capabilities of there machine. Alot of people just buy a machine and jump on the first bit of advise that suits there needs and they are off to the races with the "thats exactly what i wanted to hear" advise. Factory welds on most shlt are garbage for sure, but they are usually undercut and sloppy. Heres the differance between both. Undercut and sloppy means the equipment comes home still hanging. Cold lap means shlt is gone, on the highway, in a field, on someones head, or breaks off the back of a atv going up hill and crashes into your son with a pole saw hanging out of it that was following you. They serve a purpose no doubt, but just not for what most people believe. Dont be so quick on judging comments or advise.
   / Welding 3/16" & 1/4" with 120v wire-feed #35
Welds look good, if it breaks, grind it out and weld it again. That's what we have welders for, to fix and make stuff.
You might want to be careful if someone tells you, you can't do that and you tell them to hold your beer and watch this. THEY WANT YOUR BEER, drink the beer and give them the empty can to hold, then show them how's it done.
   / Welding 3/16" & 1/4" with 120v wire-feed #36
The funny thing is I have a 220 stick/tig machine but have contemplated a small mig for convenience. Is that backwards thinking?
It will NEVER break. Even if it wasn't welded on the backside (which it is).
Weldermike, are you really a welder & what do you build? Those welds on the ATV hitch is 10X as strong as it needs to be, this is something I know from experience, not just trying to appease somebody on the internet.
   / Welding 3/16" & 1/4" with 120v wire-feed #38
Not in my book... never enough tools... and never enough storage space. Need more tools to make more storage space.
   / Welding 3/16" & 1/4" with 120v wire-feed #39
And more storage for the more tools... it's a viscous cycle.
   / Welding 3/16" & 1/4" with 120v wire-feed #40
Is that because of digital settings? On my 211 I can 'dial' it up past the 1/4in in 110v but I imagine there is no more output power generated unless I switch to 230v.
91013 (A48082)
91013 (A48082)
2013 Hyundai Sonata Sedan (A50324)
2013 Hyundai...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
