3 rear remotes on a John Deere 1026R
   / 3 rear remotes on a John Deere 1026R #21
That is a super nice job. Does it require a double flare and what did you make them with ?
Scott
Scott
Thank you.
They are regular 37 degree flares. I used a Mastercool hydraulic flaring tool to do the flares.
   / 3 rear remotes on a John Deere 1026R #23
Thank you.
What size tubing will fit the Imperial 370 tubing bender?
   / 3 rear remotes on a John Deere 1026R #25
So please tell me what you will use 3 remotes for? Top and tilt is 2. What about the 3rd??
   / 3 rear remotes on a John Deere 1026R #26
On a rear blade to adjust the angle of the rear blade. The top would adjust the angle of attack the tilt would adjust the blade to follow the ground as it lays and the blade angle adjusted by the 3rd.
On a box blade the usual top and tilt, and for the same reasons, and a 3rd for hydraulic rippers..
James covered it. I also plan to add a hydraulic dump trailer in the future.
   / 3 rear remotes on a John Deere 1026R #28
And in the OP's case, it's little more money to add 3 over 2. If he rarely uses the 3rd it's still better than needing a 3rd and it not be there. Go 3 every time money allows it.
Also it takes the same amount of fittings, line & time no matter if you are installing a 1 or 3 spool valve.
The total cost of the 3 spool install was still less than if I had got the John Deere single rear valve, plus I also have a power beyond that I would have been able to have with the JD rear valve.
   / 3 rear remotes on a John Deere 1026R #30
You did good Chevy!!!!
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A54607)
2017 INTERNATIONAL...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
2015 Ford Focus (A51694)
2015 Ford Focus...
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
HYSTER H55VM STRAIGHT MAST FORKLIFT (A51406)
HYSTER H55VM...
