help to convert brush hog from shear pin to slip clutch
   / help to convert brush hog from shear pin to slip clutch #1
rkallaman
KNox, Pa
JD 1025R
I want to convert a 4' brush hog (Brush Hog brand) from a shear pin PTO over to a slip clutch. What do I need to know to be sure what I buy will fit when I get it home. Don't want to buy a wrong non returnable slip clutch. Any suggestions as were to buy a slip clutch?
   / help to convert brush hog from shear pin to slip clutch #2
Generally you need to know whether the gearbox input shaft is splined, or smooth, and the diameter of the input.
I had to buy some PTO shaft tubing recently, and Agrisupply.com seemed to have the mist comprehensive list of parts. You can also check with Tractor Supply....they have a fair selection as well.
On a spline shaft do you measure the dia. outside to outside of splines or solid part of shaft. Does the width & depth of a spline need to be measured or just the number of them?
JCB 5 10 56 (A50490)
Case IH 1020 Platform (A50514)
Case IH 1020...
2021 HITACHI ZAXIS 35U EXCAVATOR (A51242)
2021 HITACHI ZAXIS...
Super C Pull-Type 40ft Land Leveler (A52128)
Super C Pull-Type...
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
