ideas for mowing shoulder/ditch next to driveway
   / ideas for mowing shoulder/ditch next to driveway #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
Here's a shot of my driveway, about 600 feet long.
Over part of it, the ditch and shoulder are getting pretty weedy and tall, and I'd like to figure out a clever way to mow with a tractor. I can't really get my push mower or riding mower in there due to the irregular ground and slope off into the ditch, and I definitely can't straddle it with my L3200. Last summer I weed whacked it, but that was tedious and clumsy.
A sickle mower would be the ticket, but they are too expensive for such a small job. Wondering if there is some other idea or hack I can try.
I do have a Honda push mower with a rusted out deck, and was wondering if there's a way to salvage the motor and blade and make some mower I can hang off the side of the 3-pt, with some sort of wheels to keep it from scalping. But that would probably be a bit dangerous.
There's got to be a clever solution to this.....
   / ideas for mowing shoulder/ditch next to driveway #2
A simple solution is a tow behind mower which can be offset. A batwing cutter works great too but you probably don't want to go that route.
   / ideas for mowing shoulder/ditch next to driveway #3
A walk behind string trimmer adapted to a 3pt attached frame that sticks out to the side would be safer than a blade. Raising and lowering would be simple, extending it out and retracting is certainly doable with some design work ... maybe a telescoping tube affair pushed and pulled by a power beyond hydraulic cylinder. Maybe the folks at Everything Attachments would build something if there is enough demand.
   / ideas for mowing shoulder/ditch next to driveway #4
Spray the weeds with a broadleaf killer and let the grass grow. Mow off after it goes to seed and it may get tall again but shouldn't be too bad.
   / ideas for mowing shoulder/ditch next to driveway #5
Sickle bar might be a possibility if you spend a little time on craigslist. I see them for $300-$400 in my area occasionally.
   / ideas for mowing shoulder/ditch next to driveway #7
   / ideas for mowing shoulder/ditch next to driveway #10
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
UNUSED WOLVERINE PFF3-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2015 Toyota Prius (A53424)
2015 Toyota Prius...
