Compact Diesel trucks that we can't get here
   / Compact Diesel trucks that we can't get here #111
Not sure what you are trying to say, not sure you know yourself. HS
I'm saying you are not saving anything or gaining anything with a diesel in 2014. The days when diesels ruled from 1990 to 2002, maybe even to 2007. That era of cheap diesel and reliable low cost diesel equipment are gone .
   / Compact Diesel trucks that we can't get here #112
   / Compact Diesel trucks that we can't get here #113
You have a point B&D.... that's part of why I drive a 2001 diesel.
My hope is that present day diesels continue to evolve... they have already, to a certain extent. There is a parallel with late 70's/early 80's gas motors - emission controls on those gassers were crude and didn't last long - EGRs, cats, and O2 sensors have come a long way since then - both in terms of reliabilty, and relative cost.
Time will tell....
Rgds, D.
   / Compact Diesel trucks that we can't get here #114
I believe the days of driving a diesel rabbit on home heating fuel oil are behind us now in the USA. Was great for the wallet for a while. The reason people bought the old 6.9 Fords was to get 200 thousand miles on a truck. At a auction last week they had a company ford 250 with over 400 thousand on the original 4.9 gas motor. Bruns construction got their money out of that truck.
   / Compact Diesel trucks that we can't get here #115
The 4.9 gas engine is world famous and still being produced new today with 30 new twists.
Wet-Sleeve 4.9L Engines
   / Compact Diesel trucks that we can't get here #116
I think you are wrong, diesel is a far superior fuel when compared to gasoline. Beats gas in every way, including economy. Most of the world has already made the move away from gas, not sure you really understand modern high pressure diesels. You have have much homework to do to still hold your opinion. HS
   / Compact Diesel trucks that we can't get here #117
Diesel is a superior fuel, but in the US it costs more for diesel and with the new emi$$ions equipment that will need to be maintained the cost per mile may actually be better with a gas engine.
For example, a nearby gas station has regular at $3.759/gallon and diesel at $4.299.
Lets take the Chevy Cruz and compare the cost per mile:
http://www.fueleconomy.gov/feg/bymodel/2014_Chevrolet_Cruze.shtml said:
Diesel = 2014 Chevrolet Cruze 4 cyl, 2.0 L, Automatic (S6), Diesel
Gas = 2014 Chevrolet Cruze 4 cyl, 1.8 L, Automatic (S6), Regular Gasoline
FuelCityHighwayCombined
Cost/GalMPG$/MileMPG$/MileMPG$/Mile
Diesel $4.29927 $0.15946 $0.093 33 $0.130
Gas $3.75922 $0.17135 $0.10727 $ 0.139
Diesel-Gas
$0.545 $(0.012)11 $(0.014)6 $(0.009)
I looked at available on the lot models with those engines/transmissions and found that the diesel was $1120 more.
The number of miles that you would have to drive for a diesel to pay for the price difference in fuel savings (assuming the same fuel prices) would be as follows:
City (27MPG vs 22MPG)Highway (46MPG vs 35MPG)Combined (33MPG vs 27MPG)
96,16580,288125,091
This obviously doesn't take into consideration residual value or repair costs, but GDI might be the way to go for a car that it cheap to drive.
Aaron Z
   / Compact Diesel trucks that we can't get here #118
While modern diesels have had their hiccups, in the same vein, I personally want to see more long term data on DI gas, before owning one.
One concern with DI gas is fuel dilution in oil.... not something I want to figure out/deal with in a 2'nd or 3'rd owner vehicle, esp. one where the oil changes have been stretched out...
People tend to appreciate the high torque levels of a diesel (yes, DI Gas is catching up) more typically in trucks, but the folks I see up here who get into tdi cars (VW) drive them for a long time, and are repeat buyers.
I'm still wondering if EPA gas mileage #'s are based on E10 fuel.... I'm betting they test with pure gasoline.....
Rgds, D.
   / Compact Diesel trucks that we can't get here #119
Thankyou Aczlan . Guys like Houston can't move past the 1990-2002 era of P pump Diesel engines and burning fuel 2/3 to 3/4 the price of gasoline.
It's about cost per mile and they don't get it. One set of common rail injectors and the truck will never break even on cost vs gasoline.
Now many try to use economy, reliability etc to justify a reprogrammed diesel with stacks.
   / Compact Diesel trucks that we can't get here #120
On certain types of Deere engines, untill 2 years ago when they sorted it, it was common to replace a head gasket and a variable turbocharger every 3000hrs... which meant 3 dollar per operating hour... Which meant serious sales talk to be able to sell another, in the cost conscious earthmoving business... Turbos were improved by using stainless steel to which soot caused by EGR didnt stick (it stuck onto the turbo on the cold (intake) side, jamming the mechanism) and the head gasket problem was solved by increasing the head bolt torque by 25%.... Especially the head gasket problem, you wonder why they didnt catch that on the test bench.... But it happens when new generations of engines have to be introduced in a hurry to meet the upcoming new emission stage every 2 to three years... Luckily after 2014 the final stage takes effect, after which manufacturers can focus on reliability instead of meeting an emission deadline.
Also with soot filters, it was a relatively new OEM market (it used to be just an aftermarket) and many companies with little experience jumped into it. Now when you cant meet the current on-road and offroad emission stages without either DOC or DPF, large manufacturers test them on the testbench and sort out the poor designs i a hurry. New materials are being explored, which dont need additional diesel injection or regeneration because they regenerate on their own at as low as 250°C exhaust gas temperature, are taking over, thereby greatly improving overall reliability.
Diesel reliability will return within a year or two once the dust has settled...
HYDREMA 912HM ARTICULATED DUMP TRUCK (A52707)
HYDREMA 912HM...
2019 Ford Explorer AWD SUV (A55853)
2019 Ford Explorer...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2019 Ford F-150...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
