Tow Cultipacker with hydraulic lift
   / Tow Cultipacker with hydraulic lift #1
logankelly
winona mn
jd2520
Looking to make a towed Cultipacker with hyd. lift need pics of the ones that any of you built out there and what would you do different next time
   / Tow Cultipacker with hydraulic lift #3
My single axle cultipacker is about 10 ft wide.
Transporting it on a public road is a problem. I'd have to cut it down to about 8 ft and rig up a pair of hydraulically actuated towing wheels on the rear end. Not a big job--wheels, a hydraulic ram, some steel and your stick welder.
Good luck
I have long distance to travel to much weight to be bouncing on 3 point its only going to be 5 foot but min. weight is 1000 lbs.
flusher why would you have to cut 10 footer to 8 footer?
   / Tow Cultipacker with hydraulic lift #5
Public roads, trailer width limit, generally 96-102" (8-8.5 ft)depending on the state in which you're pulling.
If you live in Wisconsin, a new law (Act 377)increases the limits (height, width, length, weight) on "Instruments of Husbandry" (IoH) and establishes a new class of vehicle (Ag CMV).
Governor signs off on farm machinery on roads
Don't know if this applies to Interstate highways or only to Wisconsin state roads.
_
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
Ingersoll Rand SS3J5.5GH-WB Portable Gas Wheelbarrow Air Compressor (A50325)
Ingersoll Rand...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
Club Car Electric Golf Cart (A51694)
Club Car Electric...
