LocknLube adapter
   / LocknLube adapter #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
I bought one of these based upon discussions here on it. At $30 I gave pause, but I would buy again. It does help that you don't have to hold the coupler in place as you pump grease.
The short comings of this coupler....I can't get it into some spots due to it's bulk/length. With the coupler came a short note....
"You can take the standard coupler that you replaces and thread a 45 or 90 into it. Then clip the old coupler to the new coupler. Now you have a handly little adapter at no cost."
How? The back end of the coupler has threads on it to screw into your solid or flexible end of the grease gun. I need to screw in a zerk there to make this work.
What I really want in another flexible hose to screw this old coupler to, then screw a zerk some how on the other end. Then you can attach the LocknLube to the zerk on the hose. Doing some googling I found one like that, but they wanted $37+ for it.
   / LocknLube adapter #2
Check at your local auto parts store, get a zerk with the 1/8 inch pipe thread and a female coupler to the hose.
I need to rig one up for my LocknLube :thumbsup:
   / LocknLube adapter #3
When some one gets one build could they post a picture. I am having a hard time picturing this. Thanks John
   / LocknLube adapter #4
Lets try a word picture:.. Look at the pictures above for reference.. Now lets start on one end. Step 1, screw the zerk into the female to female coupler you see above.
Now get a 1/8 male to 1/8 male flexible hose. and screw one end of this flex hose into the other end of the female coupler that has the zerk.
Now screw your original coupler into the free end of the 1/8 flex hose. So it now looks like this: original coupler, flex hose, female to female coupler, zerk..
Savvy?
   / LocknLube adapter #5
Grab a 1/8" street elbow, either 45* or 90* from any hardware store. Screw a zerk into the female end of the elbow, and add your old grease gun coupler to the male threads of the elbow. Now you can pop the coupler from this new tool onto the hard to reach (odd angled) zerk, and pop the LocknLube onto the zerk end of this new tool.
   / LocknLube adapter
Actually i found zerks with 1/8" threads and the zerk screwed right into the coupler. Zerks i have seen had much smaller holes.... Didn't realize they existed.
   / LocknLube adapter #7
Re: LocknLube Adapter Extension
View attachment 379924 View attachment 379925
Used the tube, removed when I put a hose on the lever gun, to make an adapter for a recessed zerk on the TORO front deck mower.
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
2002 International 9200i Truck (A55218)
2002 International...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
