aux fan cooling for 3110
/ aux fan cooling for 3110 #1
paulBurns
Member
Carroll Co Tn
Ym3110
I have heard of others using a 12 volt DC fan under the hood to provide extra cooling for Yanmars that run hot under heavy load and in hot weather.
My 3110 tends to red light if there is a constant heavy load such as in bush hogging in hilly terrain that has a lot of heavy grass/weeds. Same if I am tilling deep for a time.
Does anyone have any experience adding a cooling fan and if so what size fan did you use and where did you purchase it.
Thanks
/ aux fan cooling for 3110 #2
You can install a pusher fan - very popular in the off roading community. HOWEVER, I would first make sure the radiator and system is working perfectly. Your tractor should not be in the red if its clean and have the right mxx in it. A radiator shop can clean it out or even rod it out too. Also a pusher fan will put more thresh (plants cuttings etc) into the radiator and clog it up and therefore not let it cool as it should.
/ aux fan cooling for 3110 #3
Agree, I think bringing the cooling system back to what Yanmar intended is a better use of the same money.
After 30 years, maybe its time for a $300 new radiator.
/ aux fan cooling for 3110 #4
I use my fx28d in AZ in 120 degrees and work it hard. No over heating. I bet you just need to clean up your cooling system.
/ aux fan cooling for 3110 #5
I agree with others. Clean every thing up , get a new radiator etc,. I've only seen the hot light come on when Grass seed stopped up my radiator screen
Thanks for the advice on cleaning the radiator. Just thinking Does it have a water pump? I know some of the Yanmars cool by convection flow without a pump.
Also if there seems to be good flow looking into the radiator top when at idle is this good enough evidence of adequate circulation.?
I only get hot in hot humid weather when I am under very heavy continuing load, throttle back hard to keep up RPMs.
Thanks Paul
/ aux fan cooling for 3110 #7
I doubt the weather in your area is any more humid or hot as the weather where I am...When I'm using the brush hog or using the loader all day. My 3110 doesn't run hot... Yes , the 3110 has a water pump. If the engine is getting hot....There is a problem with the cooling system
I will be checking out the system as is---I know that some of the little metal parts on the radiator are smashed up a little and restricting air flow a little but they are basically open and not stopped up with seeds and trash. Next I am going to pull it and check by a radiator shop.
Thanks again.
/ aux fan cooling for 3110 #9
My Yanmar only runs hot when seeds, fuzz, etc. clog the screen. Once that is cleaned it is OK again.
/ aux fan cooling for 3110 #10
I have had the same problem with my 3110D, and it got worse last summer. The light would come on and I would disengage the mower and run it at part throttle until it cooled off. The fluid looked like mud. This winter, I drained the fluid and flushed it with water till it ran clear. I could see scale in the radiator tubes through the radiator cap hole. I believe the radiator and engine passages were scaled, which insulates heat transfer. I felt like the engine needed cleaning too. I have never had a lot of luck with consumer grade radiator flush. Being in the A/C business, I see a lot of scaled heat exchangers and scaled ice machines. I poured a pint bottle of nickel safe ice machine cleaner in it and ran it for several hours. Nickel safe ice machine cleaner is inhibited phosphoric acid, which dissolves iron rust and lime or calcium scale. I flushed it real good with clean water and refilled it with a 50/50 mix of water and antifreeze. I read this back in May but didn't want to say anything until it warmed up enough to be able to tell if it made a difference. Now that it has warmed and the grass is growing again, I have put it to the test. We had a week of rain and when it dried up enough to mow the place was a jungle. I really put a load on it, and the light did not come on once.
Anytime you put an aggressive cleaner in your engine you run the risk of breaking something loose that is plugging a hole. Or if something is about to give, the cleaner can finish it off, so if you decide to use a cleaner, keep in mind it can cause a leak. I felt like I had nothing to loose, so I went for it.
Another note, when any engine is run hard then immediately shut off the engine actually gets hotter before it starts to cool off. All the heat has no where to go when the engine is taken from high rpm to stop. It's always a good idea to idle the engine a few minutes with no load to give it a chance to cool before shutting it down. This will extend the life of your engine. When engines run hot, pistons expand. When they cool off, the pistons contract. They can contract more than they expanded. This can cause reduce compression and increase oil consumption.
Did you solve your problem?
Thanks for the reply.
Sounds like something I should do but I am waiting to see just where I stand with mine now. I have not had a good heavy load on a hot day yet. I did flush mine with auto-parts store cleaner and got some stuff out but not a lot.
I have another question---where is the no. 1 position on your pto when looking at it facing the shift.
Reason I ask is I think mine is on the bottom right BUT the operation manual I recently bought shows it on the top left. Called Hoye and they did not know except for the manual's info. Thanks
/ aux fan cooling for 3110 #12
sitting on the tractor... PTO shifter should be on the bottom left for about 540 RPM
/ aux fan cooling for 3110 #13
I would concur on that statement as well for the YM2500/YM2610 in the same PTO 4 selection shifter.
These Yanmars share a bunch of engine, powertrain and body parts ... 336, 2500, 2610, 3000, 3110, 3810
Lower left = PTO-1 542
Upper left = PTO-2 685
Lower right = PTO-3 1005
Upper right - PTO-4 1268
At or around 2200 engine rpm typically.
Thanks for the help on the PTO position for 540 RPM, that did seem to be the slowest to me just by the sound of the attached bushog. Now that I have used bottom left position sitting on the tractor it makes everything sound right when cutting the weeds and grasses. Also it has not overheated since I started using the 540 setting.
I wonder if using the 3 position as I was doing was the cause of my overheating problem in the past. I also feel lucky not to have damaged something by using the wrong speed.
Thanks again for the info.
/ aux fan cooling for 3110 #15
Well, PTO-3 would run the RPMs at TWICE the speed "if" running around the 2,200engine rpm. Thus, the more speed, the more the heat. I've kept the bushhog and finish mover no greater than PTO-2 685rpms, but at a lower engine speed, therefore the balance comes out around the 540rpms without the higher engine rpms. Mowing is so much quieter and enjoyable. Does your hour/meter show the four PTO rpm speed curves? If so, you can understand what I'm talking about here.
/ aux fan cooling for 3110 #16
I noticed some scale building up in my 3110 and drained it down far enough to hold a gallon of vinegar. I then ran the engine up to normal operating temp for a few minutes and shut her down. I left the vinegar in all night and drained it the next morning and flushed the system twice. The water I drained out was brown and the inside of the radiator flues was much cleaner, not perfect but noticeably cleaner. I then put my antifreeze mix back in and everything was OK. I do this to my water cooled motorcycle every 2 years or so and it keeps the system clean.
2017 VOLVO SD45B PADFOOT ROLLER (A60429)
2017 VOLVO SD45B...
Attention (A57148)
Attention (A57148)
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
UNUSED FUTURE P45-56" MINI HYD BREAKER HAMMER (A60432)
UNUSED FUTURE...
(2) UNUSED 31" X 10 MM EXCAVATOR TRACKS (A60432)
(2) UNUSED 31" X...
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
