Kubota BX2200 oil filter cross reference
   / Kubota BX2200 oil filter cross reference #1
millwrightdude
Its time to change the oil and filter in my BX2200 and I would like to use filters other than what the dealer sells. Has someone crossed the filter over?
   / Kubota BX2200 oil filter cross reference #2
These are Wix filter numbers. Enjoy!
So its a Wix 51064?
Thank you
   / Kubota BX2200 oil filter cross reference #6
And as usual the fuel filter Wix 33972 is incorrect no BX or other Kubota uses 50 micron a screen for a fuel filter. This is why I do not trust the Wix cross reference guide.
Wix Fuel Filters 33972
David Kb7uns
   / Kubota BX2200 oil filter cross reference #7
David Kb7uns
What is the micron rating for the kubota fuel filter? Is there a "correct" alternative from another manufacture? (Napa, FRAM, etc).
   / Kubota BX2200 oil filter cross reference #8
Do not know what the micron rating is on the Kubota filter is. I think Kubota had these made just for this type of application just for them as it is a water blocking paper element inside an inline housing. I would think that they are in the 10 micron range as they do block water from fuel without dispersal agents added, have not found any specs for them though.
On my RTV1100, G2160 and BX2230 I have adapted the newer B series water separator between the lift pump and injection pump, as I was having water get past the first filter to the second and it does a good job catching the water.
David Kb7uns
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A49346)
2025 Kivel 42in...
2020 VOLVO VNL860 TANDEM AXLE SLEEPER (A45679)
2020 VOLVO VNL860...
New/Unused 20ftx20ft Steel Carport (A48837)
New/Unused...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A50046)
2012 VOLVO VNL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
