Where to find install manual for 62D on my 2520?
   / Where to find install manual for 62D on my 2520? #1
Deadman
WI
John Deere 2520, X475
I recently bought a used 62D MMM for my JD 2520 and would like to know where to look for installation manual, any suggestions?
I found that one, but I didn't know if there was a different manual for actually installing the mounting brackets to the tractor itself? I bought a used 62D and its coming with all the brackets, but I just wanted to see if there was a sealer install manual for the first time install to put brackets on the tractor itself?
I'm hoping all the brackets are with my mow deck when it arrives, but I would like a manual to determine if all the parts are there before I start installing things. I would rather have the extra parts needed on hand before I start installing it, but if not I can see how it goes after it arrives.
Thank you for the link!
   / Where to find install manual for 62D on my 2520? #4
There were a few different versions of the mower lift kits 2520.
You can find the parts lists at John Deere - Parts Catalog
Just need to figure out the lift kit that you have.
   / Where to find install manual for 62D on my 2520? #5
You will have to get the "install" manuals from JD I believe.
   / Where to find install manual for 62D on my 2520? #6
Here is a copy of the installation instructions.
  • 2520 mower lift.pdf
David White LT6-900 Level Transit, S/N C500926, Model 8834 (A59076)
David White...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
2021 Ford F-150XL (A57148)
2021 Ford F-150XL...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
