When / How do you engage the PTO on your DK?
   / When / How do you engage the PTO on your DK? #1
Beezz27
Gastonia, NC
2013 Kioti DK40SE HST, 1975? Ford 3000
Obviously I know "flip the PTO switch" I get it BUT....... do you idle the tractor down, flip switch, rev to the 540 mark........OR... do you just flip the switch at operating RPM? That brings me to the next question what about the AUTO PTO end of things? After the first time engaging the PTO at operating rpm and seeing the TREMENDOUS amount of torque on the tractor and bush hog I now engage at idle then rev to the 540 mark. I don't use the auto feature while cutting because of the torque but I do with the tiller (shorter shaft, less mass). Is there any "slip clutch" to the PTO in the tractor or is it true on/off straight gear? The only other tractors that I have used the PTO engaged with the clutch pedal so it could be eased on as the clutch let out. I love the auto feature but don't want to tear up my tractor.
   / When / How do you engage the PTO on your DK? #2
I idle the engine before engaging the PTO if I remember. I don't always remember. I use it in the auto switch position but don't really use the auto function except as a backup in case I raise the 3PH and forget to disengage the PTO. High RPM PTO engagement can't be good for the equipment but (so far) hasn't damaged anything as far as I can tell. I don't do that often.
   / When / How do you engage the PTO on your DK? #3
I always start my PTO at idle, then throttle up.
I never use the auto feature.
   / When / How do you engage the PTO on your DK? #4
   / When / How do you engage the PTO on your DK? #5
Hmmmm, guess I need to start throttling down?
   / When / How do you engage the PTO on your DK? #6
Ditto :thumbsup:
x3.. Even though the PTO is engaged with a electric over hydraulic assembly and therefor is supposed to be "easier" start.. didn't look too easy to me on the rotary cutter. It seems way safer to idle down and engage then throttle up. As for the auto, never use it, but figured it would be OK for something with low mass to startup like you said.
   / When / How do you engage the PTO on your DK? #7
Worked for 30 min too get the blades unstuck on the neighbors M5100 with mounted 6 ft mower after he engaged the mower at full throttle. the blade attached disk started up so quick that the blades just cross them self in the middle of the disk.
   / When / How do you engage the PTO on your DK? #8
yeah, I want to avoid something like that if I can. There is nothing like winding up a tractor and "dropping the hammer" on what amounts to a big mass of steel that takes a while to spool up.
   / When / How do you engage the PTO on your DK? #9
I recommend it.
The PTO turns on hard/fast. You don't want to be throttled up to turn them on.
Just adds unnecessary damage to machine and implement.
   / When / How do you engage the PTO on your DK? #10
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
