Floor/crawl space Insulation ?
   / Floor/crawl space Insulation ? #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
code here is R-13 in a crawl space should I increase the R value ? I have until this Tuesday to make a decision. $300 upgrade to R-15, upwards from there as it increases. Batts the spray would be 1/2 the cost of the entire job.
   / Floor/crawl space Insulation ? #2
I can't imagine you'd notice any difference between R-13 & R-15.
   / Floor/crawl space Insulation ? #4
Always felt the more the better. Spray in type would be better if you can stand the cost and will not have to worry about the batts falling down later on. Just my opinion mind you
   / Floor/crawl space Insulation ? #5
In a crawl space I would go for spray foam.
The rodents sure like wool batts as nesting sites.
   / Floor/crawl space Insulation ? #6
Hey, neighbor... go for the most you can afford. Do it once, do it right...
   / Floor/crawl space Insulation ? #8
I had my floor insulation pulled out last Nov. It was just a moisture magnet and rat/mice haven. Moisture levels in the crawl space dropped to an excellent 15-16% and we noticed no colder floors this cold winter then before (well, cold for us).
Good luck!.
   / Floor/crawl space Insulation ? #9
Good luck!.
Now hold on ftg, ye ain't got nary insulation now in ye crawl space? Hmmmm, I need to do something. No matter wha' ye do, make sure the ground is covered real good with about 6 mil polymollymajolly, wha' ever it's called. Y'all know.
   / Floor/crawl space Insulation ? #10
Nope, no insulation for the last year - this is my now previously owned house, it got sold a couple weeks ago.
I have several layers of 6 and 10 mil plastic installed. It's a very dry crawl space, which is what I wanted.
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2017 Ram 4500 Bucket Truck (A55218)
2017 Ram 4500...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52705)
2015 JOHN DEERE...
