25 hp 3 ph 230 Volt Franklin submersible pump question?
   / 25 hp 3 ph 230 Volt Franklin submersible pump question? #1
bjr
Eastern WA
Jinma JM354
I watched a pretty good electrician OHM the pump. My question is procedure. Power disconnected of course. The leads were put on the very bottom lugs (the heater lugs) and it read infinity across all three legs. Aside from some kind of catastrophic failure in the motor, why wouldn't we get some kind of resistance reading? I mean all three legs shown to be open? Could there be a separate breaker or device between the starter and pump? I've done some industrial electric work so I'm not clear out of my mind here. Any Irrigation pump guys out there? bjr.
   / 25 hp 3 ph 230 Volt Franklin submersible pump question? #2
You need to get a certified well guy out there to do some real troubleshooting. I would disconnect the pump and ohm without anything connected to the wire leads. Looks like it's gonna cost a lot of money to pull the pipe and pump out. Best of luck to ya.
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
25077 (A51694)
25077 (A51694)
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2001 Ford F150 (A50121)
2001 Ford F150...
