Lets talk Crossbows !!!
/ Lets talk Crossbows !!! #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
I used to shoot/hunt with the old fashion recure bows way back when and had a great time doing so.After some rotatercuff surgery about 5 years back I bought a tenpoint defender cls crossbow(330FPS).After using it a few times the bow was just to darn heavy I believe over 8 lbs.10 ounces.Yesterday I traded it on a Parker tunderhawk(320 FPS)crossbow with lighted red-dot scope that weighs in at around 6 lbs and its Very compact.I also purchased six 20 inch.red-dot carbon fiber arrows.I got her home and sighted in a 20 yards,dead nuts tack driver.What make crossbow or bow are ya shooting?
/ Lets talk Crossbows !!! #2
For years I have been a big Excalibur fan. I shoot a Vortex w/a scope and a 175lb draw older model Exocet175 w/iron sights. I 'am not compareing Excaliburs with any other brands but I prefer the recurve no cam systems myself. Less moveing parts ,less things that could go wrong , lighter in the field, and easy to restring in field if your strings breaks. I have not looked and or researched crossbows in quite a while but if I had to buy another make it would probably be a TenPoint.
Oh BTW if I had anything negative to say about my Excal's I'd say they are loud but by the time game heres it or sqwints down "bolt" which is what a crossbow arrow is called is threw them.
/ Lets talk Crossbows !!! #3
Never shot a crossbow, but I started on a Fred Bear TRX 400 a few years ago and moved up to a new PSE Sinister this winter. What a difference!!! My sinister is chrono'd at 312 fps @ 60#, 29" draw. I'm shooting a 4" group @ 40 yds. At only 28" axle-to-axle, this one will be absolutely deadly maneuverable in the stand. I cannot wait until whitetail opens up this fall...Here's a few pics:
Sent from my LGL35G using TractorByNet
/ Lets talk Crossbows !!! #4
When you sight in, what are you using for the backstop? I'm thinking about using old haybales. Trying to figure out what's gonna damage bolts the least.
/ Lets talk Crossbows !!! #5
I'm pretty sure any decent crossbow is going to blow through a hay bale, my bow did it when I missed the bag target a couple times. We use a shooting lane until we get it where we're not likely to miss the bag now.
/ Lets talk Crossbows !!! #6
When sighting in a crossbow if I don't have have a good rest or one near by I use my pole cat single leg shooting stick.
BTW these sticks have giving me great results with a rifle also at long ranges in areas where there was not a good place for a rest. Pole Cat makes a dang good shooting stick with the Will Primos name on it . Sold in Wallmarts for about $50.
I am using a magic stop bow target.Arrows come out real easy also.
/ Lets talk Crossbows !!! #8
As I have gotten older I load mine with a rope cocking device. I can also load my string with gloves on easier , but with bare hands it can be a bear if I didn't eat my Wheaties that morning. I'am talking about 200 lb plus draw weights.
Anybody shooting a crossbow with built in rope cocker ? I would imagine that will add extra weight to your rig.......
My tenpoint had the built in rope cocker and it did add weight.IMHO don,t like the built in ones.
/ Lets talk Crossbows !!! #10
I found a Man Kung-180 on ebay, and at the last 5 seconds it was still around $50, free shipping, brand new, and came with 20 arrows. I figured I can't pass on it for that price. The scope that came with it is cheesy, the arrows where pretty cheaply made, but it's been fun to play with. It was advertised as 180 lbs by the eBay selller; but turns out it's 130 lbs according to Man Kung online. I shoot at a 50 lbs chicken feed page full of well packed sand. No pass through.
/ Lets talk Crossbows !!! #11
There is a crossbow store/shop in Sardis , Ohio owned and run by a guy named Dan Miller. The name of the shop is Horizontal Archery. Danny has got to be one of the leading authorities on crossbows in the world. Their prices are very competative and they will send you your crossbow already sighted in for those that have troubles doing it. At one time and its possible that they still don't even have a website. Just old school honest to goodness people to deal with. I'am in no way related to them and crossbow websites are just filled with positive experiences dealing with Danny.
/ Lets talk Crossbows !!! #12
I have an older TenPoint Stealth X-2. Sent it back to TenPoint two years ago for a string/cable change and a trigger upgrade. It's deadly accurate. I have a rope cocker (not built in). My first scope was an illuminated red dot scope. Sometimes the battery would die on the red dot scope without warning. The scope without the red dot isn't of much use so I went to a cross hair scope. These are good targets. They will take lot of shots from broad heads and hold up well. Not easy to pull bolts out of though:
Rinehart 18-1 Target at MacksPW.com
/ Lets talk Crossbows !!! #13
While I don't have a crossbow or hunt with a bow (can't get good consitant hits). I have learned that square bales will stop the arrows every time if you turn them to where an end is facing you. And make it shoot through the leafs not between them. Takes more bales just make sure you keep them tight. If doing a lot of shooting put some stakes on each side.
/ Lets talk Crossbows !!! #14
I have a friend that purchased a cross bow last fall;he started shooting it indoors last winter.What we found out that the strings are only good for about 150 shots.This is a quality and expensive x bow.String change-out/labor is $90.00.Pretty expensive shooting.
/ Lets talk Crossbows !!! #15
If you rube them with wax they last better. Also, you can rest ring with a special wire stringer, costs like $9
/ Lets talk Crossbows !!! #16
Pics of my Excalibur Exocet 175 (stock sights) . Excal recommends when not going to use crossbow for a while to de-string, and take off dissipator bars and pads.
They have also come out with a S5string suppressor system which people claim redoices noice levels even more. Don't have those on any of my crossbows (yet).
Last pic is S5 system ////// Please excuse my beat up pads these must be 8 to 10 years old
Excalibur Crossbow Forum
2019 CATERPILLAR 299D3XE SKID STEER (A60429)
2019 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2019 Chevrolet AWD Equinox SUV (A59231)
2019 Chevrolet AWD...
Here are some similar links:
