Homemade Sportsman 570 2" hitch
   / Homemade Sportsman 570 2" hitch #11
110v... NOOOO! Seriously, very nice job and pictures. Thanks for posting. Oh and those welds are purty!!!
Thank you Sir. Like I've said before; what I lack in welding skill (and machine), I think I kind of make up for in design. I try to make things with as much weld area as possible... bevel the sh*t out of things, and weld both sides when possible.
   / Homemade Sportsman 570 2" hitch #13
Joint prep makes or breaks anyone. Bevels, and gaps are a huge help! That's why on the job the engineers always give you a WPS to work to. ;)
Here's a better shot
What it's supposed to have... but doesn't spring worth a darn
I plugged up the holes so they wouldn't hold water.
I do have something in mind as a replacement for that holder... I'll see what I can find.
   / Homemade Sportsman 570 2" hitch #15
Same here, I try not take any chances with my welds.
Very nice job - as usual!
   / Homemade Sportsman 570 2" hitch #16
WPS?
Wi-Fi Protected Setup?
Worldwide Port System?
Wireless Provisioning Service?
Worst Possible Scenario?
White Powdery Substance?
Work Package Status?
Worthless Piece of Stuff?
Throw us a bone here!
   / Homemade Sportsman 570 2" hitch #17
The engineers usually prefer it built to standard MIL-TD-4111 but the WPS probably specifies that.
   / Homemade Sportsman 570 2" hitch #18
Welding Procedure Specification.;) A lot of times it can be listed on the welding symbol too.
   / Homemade Sportsman 570 2" hitch #19
OK WPS is on a drawing so it would fall under MIL-TD-4111 :D.
Here's my WPS (not specified on my drawings)
If penetration may be insufficient, bevel or space.
If water might get in and spill rust, weld to seal it up.
If one side is strong enough, weld on 2 sides.
If 2 sides is strong enough, weld 4 sides.
If my weld may look better than the joint preparation, weld it.
If I think the next weld might look better than the last, weld more.
If I have nothing better to do, weld 4 sides.
If better things to do but still in honeymoon phase with a new welder, weld 4 sides.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51692)
Heil V-1722 28Yd...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
