Welding a 1 1/4" solid steel shaft (a repair story)
   / Welding a 1 1/4" solid steel shaft (a repair story)
Probably 90% of my welding is in my barn off grid, using a paired set of Honda EU2000i at 120v. But I'm on the lookout for an 8,000w generator.
   / Welding a 1 1/4" solid steel shaft (a repair story) #12
Nice post and write up
   / Welding a 1 1/4" solid steel shaft (a repair story) #14
Nice job.
   / Welding a 1 1/4" solid steel shaft (a repair story) #15
Very nice work. Especially in the creativity in your low cost fixturing and jigging.
I was pretty proud of some rake bars that I have repaired with primitive wood jigging that are both perfectly true while also being invisible to the human eye, but my repair does not compare to this one even though I did use my Lincoln SP-135P (115 volt wire feeder) to do it.
   / Welding a 1 1/4" solid steel shaft (a repair story) #16
I like your fixturing and jigging too. I hope I'll remember if I ever need to weld a shaft.
   / Welding a 1 1/4" solid steel shaft (a repair story) #17
yes, quite creative! Well done. I am sure I would never of tackled something like that before reading this.
   / Welding a 1 1/4" solid steel shaft (a repair story) #18
Impressive results. Good old yankee ingenuity on display. Well done.
   / Welding a 1 1/4" solid steel shaft (a repair story) #19
Nicely done!
   / Welding a 1 1/4" solid steel shaft (a repair story) #20
[note to self: search on "Soda/Sode/Sodo/120 VAC welder" if I ever need to weld a shaft back together again!]
2002 Ford E-150 Passenger Van (A51692)
2002 Ford E-150...
DOOSAN DL300-3 HYD 4N1 114" BUCKET (A51247)
DOOSAN DL300-3 HYD...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
