Why hasn't it been invented???
   / Why hasn't it been invented??? #1
Grunt0311
Paw Paw, MI
John Deere LX 277
So I am probably ruining an opportunity for an early retirement, but I just have to know if anybody else has wondered this. Today I was getting frustrated trying to level the deck on my JD LX277 AWS. I have one of those plastic gauges from JD, but while it helps, it is a pain to use. I was constantly wiggling from front to back, left to right, spinning the blades, uggghhh :banghead: The thought occurred to me, we use lasers for everything now, including leveling, checking temps, etc. Why hasn't someone invented a laser that is small and relatively flat, that you can slide under your deck, hit a button, and get a height measurement for each blade tip :confused3:. It seems like it would be a relatively ingenious idea, and make quick work of leveling a mower deck, which seems is constantly losing its level (I think I have gremlins in my shed that do this just to watch me get frustrated)! Has anybody else had this thought??
   / Why hasn't it been invented??? #4
the "laser" would get covered in dirt and give incorrect readings real quick ..... the circuitry / program is available already in hand held measuring devices ... for under $100.00
   / Why hasn't it been invented??? #5
I use the stick on RV levels and run my cutter about 1/2 bubble lower in the front to provide a good cut and use minimum HP. I also stuck them on several implements. They are cheap, easy to install and very functional.
   / Why hasn't it been invented??? #6
why not get rid of the blades and have lasers cut the grass ... has anyone had this thought? :)
   / Why hasn't it been invented??? #7
I know why not invent a mowing deck you don't have to relevel every time you rise it and lower it?
Jeez, as if maintaining a piece of machinery and keeping blades sharp weren't enough work.
I'd get rid of the piece of junk.
   / Why hasn't it been invented??? #8
I set my deck three years ago and have never checked it since. My turf has never complained nor have I.....maybe I need some laser glasses.:D
   / Why hasn't it been invented??? #9
I've never leveled anything on my lawn mower and it cuts just fine. I do sharpen the blades annually so that the rocks, sticks etc I hit get a sharp, clean cut.
   / Why hasn't it been invented??? #10
I can tell we'll need the laser level to make sure all the grass is cut at the same height on your lawn oosik.
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
1261 (A50490)
1261 (A50490)
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A54313)
2012 INTERNATIONAL...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
