Why hasn't it been invented???
   / Why hasn't it been invented??? #1
Grunt0311
Paw Paw, MI
John Deere LX 277
So I am probably ruining an opportunity for an early retirement, but I just have to know if anybody else has wondered this. Today I was getting frustrated trying to level the deck on my JD LX277 AWS. I have one of those plastic gauges from JD, but while it helps, it is a pain to use. I was constantly wiggling from front to back, left to right, spinning the blades, uggghhh :banghead: The thought occurred to me, we use lasers for everything now, including leveling, checking temps, etc. Why hasn't someone invented a laser that is small and relatively flat, that you can slide under your deck, hit a button, and get a height measurement for each blade tip :confused3:. It seems like it would be a relatively ingenious idea, and make quick work of leveling a mower deck, which seems is constantly losing its level (I think I have gremlins in my shed that do this just to watch me get frustrated)! Has anybody else had this thought??
   / Why hasn't it been invented??? #4
the "laser" would get covered in dirt and give incorrect readings real quick ..... the circuitry / program is available already in hand held measuring devices ... for under $100.00
   / Why hasn't it been invented??? #5
I use the stick on RV levels and run my cutter about 1/2 bubble lower in the front to provide a good cut and use minimum HP. I also stuck them on several implements. They are cheap, easy to install and very functional.
   / Why hasn't it been invented??? #6
why not get rid of the blades and have lasers cut the grass ... has anyone had this thought? :)
   / Why hasn't it been invented??? #7
I know why not invent a mowing deck you don't have to relevel every time you rise it and lower it?
Jeez, as if maintaining a piece of machinery and keeping blades sharp weren't enough work.
I'd get rid of the piece of junk.
   / Why hasn't it been invented??? #8
I set my deck three years ago and have never checked it since. My turf has never complained nor have I.....maybe I need some laser glasses.:D
   / Why hasn't it been invented??? #9
I've never leveled anything on my lawn mower and it cuts just fine. I do sharpen the blades annually so that the rocks, sticks etc I hit get a sharp, clean cut.
   / Why hasn't it been invented??? #10
I can tell we'll need the laser level to make sure all the grass is cut at the same height on your lawn oosik.
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
ITEM LOCATION (A53084)
