Getting paid for hay
   / Getting paid for hay #21
Around here, it depends on the land (how much and how good).
some have marginal land, smaller, say less than 10 acres is usually free (landowner gets nothing) or better land, $25/acre and up rent or sharecropped where the landowner gets a share of the crop.. often they get a share of the expense also. If smaller than 5 acres, often the landowner has to pay the farmer to farm it (cheaper than taking care of the weeds themselves). I have seen those deals as high as $1000 per year for the farmer to take care of 5 acres. In that case, the farmer is hired by the landowner and I would expect them to work with the landowner to avoid the disturbances noted above...
We like the cash rent (actually a check, with appropriate 1099) and we don't have to worry about expenses or whether we got our share of crop.. We still take care of the acreage not in crop (mowing and spraying as needed)..
Trend lightly or you may end up maintaining your own weed patch.
   / Getting paid for hay #22
I rent from several different owners and the agreements range from $40 a acre to free for keeping it cleaned up, but none of it comes with any restriction on when I can work. During the spring/fall we will log as many hours after dark as we do during the day. Nothing unusual for us to work until 3 or 4 am if needed.
People here wouldn't give me working while they partied a second thought (they would probably be out in the field watching or wanting to talk), but folks around here are use to farming and understand when
it's time to go, you go
   / Getting paid for hay #23
You could do a conservation program like CREP, here is a link to the Kansas site Agricultural Conservation Easement Program | NRCS
I Crep'ed about 2 acres of eroding at times swampy land. It was costing money to mow and time spent working on it. I am at the point now where it is on its own. I just collect a yearly check for keeping it natural. If you decided to go this route the work is not hard. I would go with tubex tubes, and buy your trees from lawyer nursery.
   / Getting paid for hay #24
Mainly the way it is here. Only we try to stop by midnight.
If it was me and you came in saying I couldn't work while you partied. I would have to look real hard to make sure I needed your ground or just cull a couple old cows and tell you to have fun mowing it. But that's me.
   / Getting paid for hay #25
Yep, if someone is performing any free upkeep to your property with thousands of dollars worth of their own equipment, you can't really say too much to them about when the work needs to be done. There is no money in hay, the money is in what the hay is used for. Be thankful your property is 7 acres of AG land rather than assessed as a 7 acre yard and tell them to keep up the good work. You're well compensated by the tax breaks it provides.
   / Getting paid for hay #26
I would agree with you.
   / Getting paid for hay #27
I couldn't say it better but it's worth repeating. Just curious though - why would someone run a brush hog just for the sake of mowing 10 - 20 acre fields?[/QUOTE
That's to keep the bushes down. Some of us hate seeing good fields go back to brush.
   / Getting paid for hay #28
I will third that
We were bailing on the 4th and usually do most every year depending on the weather.
You gotta make hay when the sun shines
   / Getting paid for hay #29
One thing you have to remember is this is my property, not theirs. A courtesy call would have been the right thing to do to see if I had anything going on that day. Keep in mind I get nothing out of this deal, if I have to brush hog the highway frontage in front of my house to keep it looking nice then that's what I will do.
You would probably be better off to just mow yours and then you could have full control of when tractors operate and when they don't, while you are partying a lot of farmers are trying to make a living and in hay, you have to strike while the iron is hot.
   / Getting paid for hay #30
ok 1st you want to keep your ag exemption in place.because as sais if you dont your taxes will be outragious.now most around here sell hay standing at $5 a round bale or they give it away just to get the pasture cleaned up and to keep their exemption.mind you it takes alot of time and fuel for some1 to bale a small place.
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
STEEL SLINGS (A54757)
(4) UNUSED LANDHONOR PINS (A54757)
(4) UNUSED...
