Buying Advice Compatible, smaller, older tractor, similar to an International Harvester 574
   / Compatible, smaller, older tractor, similar to an International Harvester 574 #1
rnk
Shropshire
International 574
Hi,
I bought a small farm (in the UK) in 2012 and I now have one International Harvester 574
(diesel) tractor for use on it. My main jobs are going to be related
to hay-making (55 acres) and boring holes for fence posts and tree
planting jobs. I may need a log splitter attachment and a few other
"extras", but essentially, I am finding that one tractor is not enough
for what I need to do. The IH 574 is the ideal size for my land and access tracks.
I need to buy at least one more tractor. As I am short of time and
labour, I want to plan so that I only need to become familiar with the
layout and mechanicals of one type of tractor and to able to keep the
minimum number of spare parts that are common to all my tractors (two
or more).
This gives me a couple of options. I could buy another IH 574, but
there aren't so many for sale (they are fairly old...!). I could also buy the nearest similar
model that has the maximum number of common parts, but I do not know
how similar, or different, each of the IH models are. I am
particularly interested in things like wheels and tyres, in case of
punctures. I would like to have one common wheel, tyre and
bolt-pattern on my tractors so that one spare wheel could fit all the
tractors, as any one could get punctured or damaged at any time,
etc...
As reliability, functionality, ease of maintenance and availability of
spare parts at low costs are my priorities, I would also consider a
totally different brand of tractor if there were significant
advantages to a manufacturer other than IH.
With these point in mind, could you recommend the best models that I
should look at that can satisfy most of the above points?
Any advice or opinions welcomed...
Regards,
Rob
   / Compatible, smaller, older tractor, similar to an International Harvester 574 #2
Maybe ask this question over at w-w-w.red-power-magazine-dot-com/forums/ for best IH info (clean up URL address).
I assume common in UK are Ford and Massey as well as IH. If you could find a Ford/NH 7710, 7740, etc, (OR 6/76XX variants if you don't need/want row-crop) they were good machines made in UK and could be found a little newer. Or similar MF/Agco if you can find. I have good luck with White 2-70 AND 2-85 in that size but don't know what Agco support would be in UK, but I would guess pretty good. Good luck.
Hi,
or more).
etc...
Regards,
Rob
   / Compatible, smaller, older tractor, similar to an International Harvester 574 #3
How much horse power are you after?
I've been looking at a new 85hp kubota for commercial grass cutting, couldn't come close to budget with a JD of similar power/spec, then got offered a deal on a case 115 farmall.
Awesome price, full spec (can, air con etc), and more power than kubota or JD.
About £28500 + vat if I remember rightly. I had to get turf tyres at about £4K but still a better deal!
In the end the contract I wanted was given to someone else, so didn't go for it.
I did consider the imported stuff (siromer etc.) as they had decent kit for very little money. Only thing was reliability, but the rep I spoke to quelled my fears regarding spares etc
   / Compatible, smaller, older tractor, similar to an International Harvester 574 #4
Chinese tractors might be worth taking a look at - despite many owners who claim they are not good.
I have a Jinma 55hp machine and it does all I want it to do. About 1/4 of the price of the larger known brands at the time I purchased it (2007).
I would take a look at the cab Dong Feng tractors - they have a good reputation. The beauty of the Chinese tractor is it is new and does not (to date) have a computer or the annoying sensors, to go wrong.
My only regret on buying the Jinma tractor is that I did not by one with a factory cab - where I live it gets down to -35C winter and +35C in the summer.
   / Compatible, smaller, older tractor, similar to an International Harvester 574 #5
I don't know if this is something your interested in or would consider. But what I would do is sell the 574 and buy a Case 45b cvt or the new holland equivalent.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53472)
2-Row Peanut...
1989 Freightliner Cabover FLA086 (A53472)
1989 Freightliner...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53472)
2020 Westfield MKX...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
