Factory gooseneck Hitch or B&W turnoverball?
   / Factory gooseneck Hitch or B&W turnoverball? #1
Wnc3
Gold Member
S.E., Texas
John Deere 820 utility, John Deere 5525, 997 JD Zmower, Komatsu PC 35 miniExcavator
I had the B&W setup in a Ram 2500 , 2006 and liked it.
Now I have a 2014 F250 that does not have the GN factory hitch ( I think it is a Reese) and wish it did.
That said, do I install the B&W or go with something else?
Thx
   / Factory gooseneck Hitch or B&W turnoverball? #2
I had the B&W setup in a Ram 2500 , 2006 and liked it. Now I have a 2014 F250 that does not have the GN factory hitch ( I think it is a Reese) and wish it did. That said, do I install the B&W or go with something else? Thx
B&W is a good hitch, probably installed 20 of them. My biggest complaint is the paint stinks.
For that new of a truck I would order the Ford factory hitch.
Chris
   / Factory gooseneck Hitch or B&W turnoverball? #3
B&W.. they also make the fifth wheel adapter that you can remove the ball and put the fifth wheel in the ball socket.
   / Factory gooseneck Hitch or B&W turnoverball? #4
Yes, we have that and I love it since I haul both GNs and a 5th wheel camper.
   / Factory gooseneck Hitch or B&W turnoverball? #5
I have had both the BW in prior F-350s and now the Ford Factory GN in 2012 F-350. I prefer the Ford but would expect it to be much higher cost than the BW.
Sent from my iPad using TractorByNet
   / Factory gooseneck Hitch or B&W turnoverball? #6
If your ordering the truck get the factory, if your adding it to an existing truck go b&w.
Brett
Thanks for the feed back. I forgot about the 5th wheel option.
   / Factory gooseneck Hitch or B&W turnoverball? #8
If you install it yourself I've got the 4" hole saw. I did it by myself in a couple hrs. Even lifted the bed instead of notching the beds pinch weld. If you need a hand give me a hollar
I installed it in several dodges and my current truck which is a '13 F250. If you want air bags too, I've got I set that just sitting since I lifted my truck.
Brett
Thanks, I may take you up on the airbags if I need them.
I already sent the truck to Master Hitch in Houton for the GN.
I hope you got your bed centered up on the back of the cab when you drilled the hole....mine came from the factory crooked and I aligned it.
I have read misaligned beds are fairly common on Fords.
(Maybe the hitch centers it up better when it goes back together)
   / Factory gooseneck Hitch or B&W turnoverball? #10
Brett
Which airbags fit with the B&W in your 250?
2013 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2013 FREIGHTLINER...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
golf cart (A55787)
golf cart (A55787)
GENERAL GENERATOR (A55745)
GENERAL GENERATOR...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
