Rotary cutter for ford 600
   / Rotary cutter for ford 600 #1
spd132
Member
What size rotary cutter is everyone owning a 600 series ford running? Been looking or a good used cutter but don't know about a 5' or 6' for this tractor.
   / Rotary cutter for ford 600 #2
it will pull a light duty 6' er .. but i would only use it for pasture clipping or light sparse brush. a 5' on the other hand can cut just about anything the front axle can make it over. w/ a 5' I've cut 5-7' tall overgrown stemmy weeds in 1st gear, max throttle, standing on running boards to see.
howse / kk are medium duty units. the lower weight makes it easier on the hyds.. etc.
   / Rotary cutter for ford 600 #3
If you get in heavy grass with a 6' you will wish you had a 5'.:2cents:
   / Rotary cutter for ford 600 #4
2012 Dutchmen Voltage V3950 42FT 5th Wheel Tri-Axle Toy Hauler Travel Trailer (A51694)
2012 Dutchmen...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A54607)
2007 POWERSCREEN...
Vermeer Chipper BC900 (A52377)
Vermeer Chipper...
6 pallets Miscellaneous PPE equipment (A53117)
6 pallets...
Kubota SVL95-2 High Flow Cab Skid Steer (A53473)
Kubota SVL95-2...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
