Concrete Patio
   / Concrete Patio #1
rmk700
Utah
Kubota L35
I'm getting a patio prepped for concrete myself and I'm getting estimates for concrete, form, pore and finish work only. The size is 33' x 17' x 4"' with two small two step steps one for house and one for garage.
I've got one estimate for $2800 so far. Does that seem reasonable?
   / Concrete Patio #2
33'x17'x4" get a good finishing guy, and hopefully ya get some good areas put in, for controlled cracking.
see what there thoughts in putting in a footer around the priemeter maybe help with some cracking at the edges.
large area, see about floor drain in a couple spots. might help with puddling of water later down the road. and aid in power washing the area to clean things up. more so garden hose to clean up spilled drinks.
make sure ground around deck causes water to move away from the concrete patio. vs pooling up at edges.
if bringing in fill to raise areas, make sure it gets compacted good, so ya don't have major cracking issues.
   / Concrete Patio #3
Be certain you understand and check/do what boggen suggests. Before you pour - have the guy/company doing the work come out and check your work. There may need to be changes made. Is $2800 a good price - good price or not - its more important that the folks have a good rep for the work they do. If they screw it up - you will end up paying more than the difference between high and low estimate just having it repaired. Sooo - before you make your final choice and before you sign your life away - ask to look at some of the jobs they have done - get an idea of the quality of their work - then make your decisions.
   / Concrete Patio
Who's putting down the stone base?
I'm doing all the dirt and base work. I was going to use a 3/4 inch drain rock for a base under slab rather than a road base aggregate with fines. That was suggested by a concrete contractor that claimed it's better for preventing heaving from temperature change. The sub grade dirt is pretty much clay dirt.
   / Concrete Patio #6
When you say that you are getting the patio prepped, what does that mean? Will it be attached or touching the house? Will you drill holes into your existing slab and epoxy rebar into those holes to tie the patio to the house? Are you using rebar or wire mesh? Wire is cheaper, but it's pure junk and impossible to keep in the middle of the concrete. Anybody who says they pull it up while spreading the concrete is misleading you because they just walk right over it again and push it back down. For a pad, I would only use rebar, and it would be set on chairs. I do not trust anything else, and I wouldn't rely on anything cheaper of faster. Rebar is proven and it works every time.
At $5 a square foot, that's a good price if it includes the concrete.
Be sure to get multiple bids if you don't already know the guy you are hiring. In every case that I've been hired to fix what others did, they guy they hired was the only one they talked to.
Eddie
   / Concrete Patio #7
Eddie
   / Concrete Patio #8
I'm getting a patio prepped for concrete myself and I'm getting estimates for concrete, form, pore and finish work only. The size is 33' x 17' x 4"' with two small two step steps one for house and one for garage. I've got one estimate for $2800 so far. Does that seem reasonable?
For my area that is very high. Going rate by me is $3.25 sq ft plus maybe $500 for leveling and gravel.
   / Concrete Patio
double post
   / Concrete Patio
triple post....grrrr
John Deere 825I Gator (RUNS) (A50774)
John Deere 825I...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
Electric Mobility Scooter (A51694)
Electric Mobility...
