3tne88 intermittent misfire
   / 3tne88 intermittent misfire #1
dougdanger
melbourne, Victoria
Yanmar vio 40-2
Hey guys, my engine develops a misfire when the revs are mid/high .. Not all the time , comes and goes but its enough to stall the engine.
If I back it off to idle it clears after a while or if I turn it off and let it sit for a while it comes good again..
As soon as I give it full load again it begins to stumble again ... Seems to get worse the longer I run it !
Filters are clan and can't see any water in the fuel ..
Any ideas ??
Cheers, Doug ..
   / 3tne88 intermittent misfire #2
Your problem sure sounds like starvation of fuel. Just browsing the service manual on that model would indicate it has a fuel feed/priming pump attached to the injector pump. If that is so, have you checked it out making sure it is functioning properly?
Yeah, my thoughts were fuel starvation .. All fuel bowls are full and the electric pump seems to be operating OK ...
Is there another lift pump ?
   / 3tne88 intermittent misfire #4
I don't know, can only comment on what I saw in the manual. It showed a priming pump with a little hand priming lever but I also think it might run off the camshaft. That type pump serves as a priming pump but also as a feed pump. Your must be completely different if it is electric.
   / 3tne88 intermittent misfire #5
I would start by replacing fuel filter(s) and bleeding fuel system. If you have SEAFOAM, use in fuel.
( Actually, first try loosening fuel cap).
   / 3tne88 intermittent misfire #6
Yes check the vent off line coming from the tank for blockage and all the filters. If the vent off line gets plugged the fuel pump will be in a bind trying to get fuel from a tank that has a vacuum pull instead of a free flowing gravity fed pump.
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
378643 (A51573)
378643 (A51573)
WESSEX RMX500 LOT NUMBER 45 (A53084)
WESSEX RMX500 LOT...
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
