It's completely unnecessary to take them apart. Waste of time. I have literally sweated in hundreds of them and never had a problem. Use water soluble flux. Just go ahead and sweat it in, use the proper amount of heat, apply it to draw the solder as the solder flows toward heat. No wet rags needed. Once the solder sets, spray the joint with a spray bottle that has some detergent in water. Wipe off the water with a damp rag and you're done. I always set the handle to half open during the process. Always use lead free solder in potable water systems. It takes a bit of getting used to if you are familiar with lead solder, but it works very well and makes a stronger joint than lead. I would not use the push together fittings for a permanent system or where they cannot be reached, like in walls.
