new member hydralic oil leak
   / new member hydralic oil leak #1
jeremyarcher054
empire, al
2008 kubota l2800
hello found site though search new member now i have a kubota l2800 leaking hydralic oil bad trying to trace down cause
   / new member hydralic oil leak #3
Leaking from where, transmission or a fitting.
   / new member hydralic oil leak #4
through the transmission
   / new member hydralic oil leak #5
something is not right here.Welcome from Wisconsin.
   / new member hydralic oil leak #6
I know it is as if the seal is out or it is pumping fluid out I am not sure just hope I will not need to split the tractor apart got the tractor from a so called friend just needs a tire youj know
   / new member hydralic oil leak #7
Got phone to take a pic of the source?
Most all of us have had to trace hydro leaks from time to time.
   / new member hydralic oil leak #8
There's two separate posters on this thread confusing things. dadglen, asked the same question on the parts / repair forum and now hijacked this thread. I gave him an answer to his leak problem on the other forum and he has not responded back.
hope this clears things up
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
WOLVERINE TL-12-72W - 72" HYD TILLER (A54756)
WOLVERINE...
2025 AGT QHT500FL Stand-On Self Loading Dumper (A55787)
2025 AGT QHT500FL...
Ford Tractor (A50120)
Ford F-450 Utility Truck (A55301)
Ford F-450 Utility...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
