Oil & Fuel Farmall H fuel valve.
   / Farmall H fuel valve. #1
Technocrat
Burns, KS
Farmall H, Ford 9N
I just acquired my dad's old H. I have not been around the tractor for a number of years. The last several years it has been sitting & rusting.
All that aside, I went out to drain several gallons of old fuel (Smells like pure varnish). The valve on the glass fuel filter will only turn about 1/4 turn in either direction. :confused:
Is there a good way to unstick this without unscrewing it from the bottom of the tank? I want to control where that old varnish goes.
Thanks in advance,
Techno
   / Farmall H fuel valve. #2
You could try to spray penetrating oil and work it back and forth. Did you try to loosen the packing nut a bit. If that is too tight it will bind.
Thanks Clint, I did. I ended up taking the gland nut clear out, & it is so corroded that the needle will not pull out. I have it soaking in penetrating oil now, will try again tomorrow.
Thanks again. There is no need to have it done quickly, I just want to get all the prep work done to start it & hear it run. Kid with a new toy & all that. :eek:
I have to wait for the new oil filter to get here anyway.
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
