JD 1530 PTO Clutch Engagement
   / JD 1530 PTO Clutch Engagement #1
newbiefarmer
Savannah
None Yet
I've recently acquired a 1530. It has the independent hyd. PTO option. I have been running a 6' bushog around the property and without a ton of experience have some questions about the performance of the PTO clutch.
1) It takes several seconds (3-5s) for it to begin turning the PTO (even at near idle), without any load on the bushog.
2) Under heavy load, the PTO will stop turning until I raise the implement. It does take a big load though (I would estimate at least 60-70% of available horsepower) for this to happen
Are these behaviors normal?
   / JD 1530 PTO Clutch Engagement #2
NO. How long since hyd filter was changed & sump screen(parts key 30) was checked/cleaned. Then I'd suggest to check trans pump pressure. It should be around 165 psi.
Not sure on when services last, I will R&R filter/screen. Any hints on where to tap into for pressure check?
   / JD 1530 PTO Clutch Engagement #4
   / JD 1530 PTO Clutch Engagement #5
I think an independent hydro PTO was an option, not sure though. If not the PT clutch is slipping.
   / JD 1530 PTO Clutch Engagement #6
You can check trans./pto clutch pressure on shifter cover under sheet metal cover that the 2 gearshift levers protrude through.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
