Bush Hog Blade Replacement_Frozen Bolt
   / Bush Hog Blade Replacement_Frozen Bolt #1
jpetropoulos
groton ma
Kubota L35
Hi All
I have a Bush Hog SQ600 with a broken blade. I am accessing the blade retaining nut from the top of the deck and even with a 5' breaker bar on a 3/4" drive socket I am unable to move the thing. I have tried penetrating oil and heat. Am I missing something?
Thanks
   / Bush Hog Blade Replacement_Frozen Bolt #2
I would say "yes".
Torch out BOTH bolts, replace both blades, nuts and bolts and get on with life. Don't waste time generating aggravation. If you don't have a fire wrench, chop out the nuts and replace both blades and nuts and bolts. Maybe try adding a pipe extention to the breaker bar and snap the bolts out.
DONE.
   / Bush Hog Blade Replacement_Frozen Bolt #3
Have you tried a pneumatic impact wrench? I have an SQ600 and that's what I have used.
Sent from my iPad using TractorByNet
   / Bush Hog Blade Replacement_Frozen Bolt #4
Hi All
Thanks
About another 5' extension on that breaker bar. Its not unusual to require 1000ft# or more to loosen a bolt thats been there a while.The ones on my bushog I tighten to 600#+ anyway.
   / Bush Hog Blade Replacement_Frozen Bolt #5
IF you resort to cutting them out, if you can get the center stump jumper nut off, you can access the blade bolts/nuts lots easier to either torch or grind them off.
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2000 FORD F-650 DUMP TRUCK(INOPERABLE) (A52472)
2000 FORD F-650...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
