OP
I found this at a local farm equipment dealer for 300. would it be capable of cutting branches up to 3/4" . I would mount it on the fel the same as the samurai.
I found another manufacturer, anyone have any experience with these guys. Looks to be more heavy duty, 375 lbs vs 70 for the samurai.
Cutter Bar TR 13 & TR 22 | Ferri-America
Wow, Coyote - while I was checking out that Ferri unit you snuck TWO posts in - Just proves I'm getting old AND slow
I bought a Samurai last year, too many other projects to get to it yet but I have a couple small cylinders and intend to build a "tinker toy set" of 2" receiver parts in order to articulate it with remote hydraulics.
Before that'll do any good, I need to finish a QA setup for my Case 580 and run remote hyd's front and rear, so (hopefully) I'll get to those items this winter.
I searched CL and other sites for nearly a year looking for an older sickle-bar to convert, finally found the Samurai and realized someone else had done most of the work for me for LESS than it would have cost to assemble the needed parts, not to mention the actual fab work
From my experience, your cutter will beat you home... Steve
Here is my two cents. The Samurai is a good idea for 1/2 in. or smaller twigs, anything bigger would probably damage the knives. After looking at the Samurai, I built one by using a 4 ft Walk-behind Gravely sickle bar. It uses basically the same hydraulic HP. The Samurai is a nice little machine but little bit overpriced for my once or twice yearly use. Also, it will not cut stuff bigger than 1/2 in.
I am planning to make another attachment, with the same concept, using either a small lawnmower deck or a standard saw blade. I do know yet, I am still playing with the idea.
Here are pics of my attachment, the only difference is that now I install the bar to the bucket. It is a simpler move without dismounting the bucket.
