Ford 4000 Industrial Tractor identification?
/ Ford 4000 Industrial Tractor identification? #1
HBR
Dandridge, TN
Ford 4000
Got # off engine block: D1NL 8051A
/ Ford 4000 Industrial Tractor identification? #3
looks like a 2030 or 4030 since it doesn't have the hard nose front like the 1801's did, look at the flat boss just above and to the rear of the starter mount, should be two sets of numbers there
/ Ford 4000 Industrial Tractor identification? #4
i can't see the front axle completely.. but do see rad rods, heavy hubs and the hook metal is from a 4xxx not a 2xxx
could have the lighter duty fixed axle.
Thanks everyone, here are more pictures...F4000-C.jpgF4000-B.jpgF4000-D.jpgF4000-J.jpg
I need to find a timing chain cover seal for the diesel engine. The pump for the backhoe/loader runs of the engine crank shaft.
tractor serial number location is on the flat area above and
behind the starter
Looks like the engine is a replacement from Ford (1971 or later)....? Still looking for information.
/ Ford 4000 Industrial Tractor identification? #8
HBR, Soundguy is right on approximate model of tractor. Can't be newer than 1964. Loader is probably a 705, backhoe need more pictures of to identify.
Parts available oem from a New Holland dealer. Many aftermarket available.
Thanks everyone, number on tractor is 41300D (1964) and number on engine is D1NL 8015A (post 1971, a replacement).
/ Ford 4000 Industrial Tractor identification? #10
Ford 750-series backhoe attachment.
They made a 750, which was 10' dig depth and had 3.5" cylinders for boom and dipper
The 753 was a 13' dig depth and had 4" cylinders for boom and dipper
The 755 was the biggest in the series with 15' depth and 4.5" boom and dipper cylinders.
The loader looks like a 730 loader. The hydraulic oil is housed in the frame. The fill will be on the top of the left (IIRC) vertical upright.
As to the tractor......The numbers you give still arent the onces on the flat by the starter. The numbers we need are stamped, not cast. Here is what you need to look for FORD CODES and SERIAL NUMBERS
Thanks, where can I find repair parts?
/ Ford 4000 Industrial Tractor identification? #12
What parts? And for the BH, loader, or tractor?
Some more common tune-up items can be found at places like NAPA or local farm stores. Like filters and belts and such.
Ford dealers are also a good source.
Other than that, just browsing online for whatever you need. There are hundreds of websites that sell parts for your tractor. but IMO there is no one-stop place. Prices range all over the place, as well as availability. Google.com is your friend.
Did you find those stamped numbers so we know what you have yet?
Thanks, waiting for it to stop raining to get numbers. Looking for seal/bearing for shaft coming out of timing chain cover to hydraulic pump. Also will need power steering pump and misc. to hook up. May rewire in future.
/ Ford 4000 Industrial Tractor identification? #14
For the seal and bearing, your best bet is to get it apart, and get the actual seal/bearing number. IF it isnt stamped on it, or no longer a valid part number, a search by size will turn up the correct modern part numbers.
The seals and bearings are likely available at a NAPA or similar store for lots less $$ than you will buy one that has a ford part #.
As to the power steering, that would be more ford specific. And there were a lot of variants to the 4000 series. And several different styles of power steering. So knowing exactly what model/set-up you have here is important.
/ Ford 4000 Industrial Tractor identification? #15
the oaktree site only covers 65-75 fords .. etc.
/ Ford 4000 Industrial Tractor identification? #16
the 41300 D translates as such:
4 172ci engine ( in this case.. D=Diesel )
1 Industrial / ag 63+
30 Utility / industrial with non adjustable front axle ( this is the light industrial axle i spoke of earlier )
*1**0 4 spd, no pto
/ Ford 4000 Industrial Tractor identification? #17
ps.. to the OP. no timing chain on a red tiger.
/ Ford 4000 Industrial Tractor identification? #18
Right as always SG.
IT was throwing me off, I thought the 750-series backhoe was only on 65+ models. I didnt catch the 1964 part.
The pre-1965 loaders and backhoes looked alot different. Not as "modern" looking.
/ Ford 4000 Industrial Tractor identification? #19
Right as always SG.
/ Ford 4000 Industrial Tractor identification? #20
Pretty sure that is a 703 loader, which would have been for that tractor. Reservoir in loader frame. The backhoe looks like a 750 series adapted to fit. In both cases, the 'true' model is on a metal plate with numbers like 19-***. The loader plate is visible in your picture on the LH loader arm. The backhoe plate is on the control tower front or on the LH main frame. The backhoe, even if it is the 10' model, is a little heavier than the Sherman backhoe typically found on pre 65 tractors.
