Cleaning diesel tank in Ford 6610
   / Cleaning diesel tank in Ford 6610 #1
hennylille
Sweden
I have a problem. It is dirt in the tank and I dont know how to clean it. I dont see any drainage hole and think the tractor is rebuilt for sweden with a cabin.
Can any one help me. I have tried to with a tractor firm but they did not fix the problems. The tractor is very weak and does not work properly. If I use a compressor to blow air from filter into the tank the problem seem to disappear, but just for a while.
Winter is coming and I need to get i working.
Many thanks in advance
   / Cleaning diesel tank in Ford 6610 #2
I have a problem. It is dirt in the tank and I dont know how to clean it. I dont see any drainage hole and think the tractor is rebuilt for sweden with a cabin. Can any one help me. I have tried to with a tractor firm but they did not fix the problems. The tractor is very weak and does not work properly. If I use a compressor to blow air from filter into the tank the problem seem to disappear, but just for a while. Winter is coming and I need to get i working. Many thanks in advance
You need to remove the tank and have it steam cleaned then thoroughly dryed.
Chris
Chris
Chris
Thank you so much for your suggestion. There is a problem though because the traktor is rebuilt for sweden with cabin and security construction to protect drive in case of accidant. To remove the tank I have to put a very ambitios work just to get it out of the tractor. I think it is 2 tanks.
Is there any ways to clean the tanks in situ?
Many many thanks for any kind of way for solutions.
   / Cleaning diesel tank in Ford 6610 #4
I had to clean my backhoe tank last winter. If you will pm me I will tell you how I cleaned mine. It was successful. But there was too much grief from the safety police.
Thank you for your wiilingness to help.
I gave up and engaged a firm. it was a huge amount of dirt from biological degradation of the swedish biodiesel. The diesel includes a part from vegetal oil.
It is not a good prognos for the future if the tractor is standimg over vinter with this biodiesel.
many thanks again fpr all help
Year: 2017 Make: Ford Model: F-550 Vehicle Type: Truck Mileage: Plate: Body Type: Regular Cab Trim (A51692)
Year: 2017 Make...
Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
Peterbilt National...
Dual Cylinder Grapple Skid Steer Attachment (A51691)
Dual Cylinder...
PALLET OF 6' X 12' SITE FENCE (A51248)
PALLET OF 6' X 12'...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
