Mahindra 5010 HST Cab Rear Remotes - Open or Closed?
   / Mahindra 5010 HST Cab Rear Remotes - Open or Closed? #1
bobm6996
Greenfield, Indiana
Mahindra 5010 4WD HST Cab, Mahindra 2615 Gear, Scag Tiger Cat 48", Gravely 42" ZTR, EZ GO Gas Golf Cart
I have 2014 Mahindra 5010 HST Cab and want to get a 3 PT Log Splitter from TSC (Speeco/County Line). The manual I found online says to tie the remote lever in the IN position to use the log splitter, that sounds like really bad advice. It also states there is a closed spool kit included to convert open center valves to closed center. What does this mean and do I have to do it?
This is way over my head. What type of rear remote comes on the 5010, open or closed?
Assuming I should absolutely not lock the lever in the IN position?
I assumed the valve on the splitter would control it. Has anyone used a splitter on their tractor rear remotes and if so, what do I have to do so I do not have to tie a lever in any position on the tractor. I am not wanting to have to do a bunch of work to get the splitter to work, thought it would be easy, hook up and go, maybe not.
   / Mahindra 5010 HST Cab Rear Remotes - Open or Closed? #2
Your tractor is an open center hyd system, so you would use the open center valve.
All of your valves are open center valves.
Look on your remote valve and tell me if you see a port labeled PB, PBY, or BYD.
I am betting you do, as that port should feed the 3pt.
If so, you have an easy fix.
   / Mahindra 5010 HST Cab Rear Remotes - Open or Closed? #3
Other than being sort of :mickeymouse: nothing wrong with tying your remote valve open to feed the log splitter. Lots of people do just that.
This way you can use what you have and spend zero money. You should be good to go as is. If you simply do not want to tie the lever in the open position, then follow JJ's instructions and he can-will help you with what you will need to do.
J_J
Could not find any letters on the valves. I took pics maybe that will help to know what I have. I am a visual learner. If you can guide me it would be appreciated. The solution I assume will still allow the rear remote to work normally when splitter is not connected.
Thanks
Bob
hat I have.
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
2001 John Deere M665 (A50120)
2001 John Deere...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
