Is #1 cylinder on a continental alwas in the rear?
   / Is #1 cylinder on a continental alwas in the rear? #1
Eyecatcher
Gold Member
Pomona Park Florida
Yanmar EX450, Ford 8N/2N, Case 580C backhoe, Massey 185
Working on Continental HD277 diesel in a Massey 85. Trying to time injection pump, to 20 BTDC as per manual, and it just doesn't work. I know that some of the old F series Continentals timed to #1 being in the rear. Anyone know if the 277 times to the rear cylinder?
   / Is #1 cylinder on a continental alwas in the rear? #2
I'm familiar with the Z series Continental engines and #1 cylinder is nearest the radiator. I never heard of any engine having #1 at the rear but anything is possible.
   / Is #1 cylinder on a continental alwas in the rear? #3
Some IH V-8 gassers were numbered non-traditionally, but I never heard of or experienced Continental doing that.
   / Is #1 cylinder on a continental alwas in the rear? #4
I've run into Continental engines with the rear cylinder being #1, but wouldn't know if thats the case for your particular model. The ones I ran into were gasoline.
Brian
   / Is #1 cylinder on a continental alwas in the rear? #5
With Continental there's no telling.
Not having any luck timing inj pump to #1 being in front. Diesel expert indicated that it might be in the rear. We'll give it a try this weekend.
   / Is #1 cylinder on a continental alwas in the rear? #7
It's worth a shot.
Supposed to time 20BTDC according to manual. Problem is, manual doesn't tell you where #1 is. Right now, it won't fire a lick. Before pulling the pump, we had the timing marks on the pump lined up, and degree wheel on flywheel said 29BTDC. We though we had it on #1. We have pulled the rocker cover to insure #1 was on compression stroke, but manual shows the drive slot for the pump being perpindicular to the block. It's not, it's about 10 - 20 degrees off. I know that Continental made some gas engines that showed #1 away from radiator end. Gonna try timing to what we now know as #4 and see what happens.
   / Is #1 cylinder on a continental alwas in the rear? #10
Did you get this figured out?
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A51691)
2016 Kubota SSV75...
2014 Ag Spray Schaben Sidedresser (A53473)
2014 Ag Spray...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A53426)
2004 HYUNDAI...
Scag STT61V 61in Zero Turn Mower (A51691)
Scag STT61V 61in...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
