Ford 5200 slow hydraulics
   / Ford 5200 slow hydraulics #1
hubert32
east central IN
Ford 5200, Ford 7200, Ford 8700, Ford 641
Have a Ford 5200 that came from the factory without auxiliary hydraulics. Previses owner added a Cross single DA remote. Changed remote 2 years ago. The 3 point lift works fine without any trouble what so ever. The problem is the auxiliary keeps getting slower and slower and to the point it won't lift some equipment. Any ideals?
   / Ford 5200 slow hydraulics #2
Can it be assumed that this problem is on more than one piece of equipment? Does the Cross valve have a relief on it? What sort of things are you lifting with the 3pt? How heavy?
I'm not sure if it has a relief valve or not.As far as the 3 point, I'm not sure the weight of a 6 row Buffalo cultivator, but lifts it no problem. Makes the front end lite.
   / Ford 5200 slow hydraulics #4
One more question. It sounds like you may have enough hydraulic pressure. Are you using different implements on the remote that you see this problem or just one implement?
Haybine, planter, disc , but did lift plow ok.
   / Ford 5200 slow hydraulics #6
Is the plow a 2 point with lift assist or 3 point mounted?
The haybine used for lift and or offset?
What size disc?
Easiest way to check what might be culprit, plug a 5000 psi gauge in remote outlet. See if it is in 2500 psi range +/- 200 psi.
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
2020 INTERNATIONAL LT625 SLEEPER TRUCK (A53426)
2020 INTERNATIONAL...
2025 Mower King SSRC (A50123)
2025 Mower King...
Electric Mobility Scooter (A51694)
Electric Mobility...
